Thread: Dans B75_266 |
Silver Member Username: Jkmago
Post Number: 202 Registered: Nov-07
| Posted on Wednesday, May 14, 2008 - 04:47 pm: |
For those still for B75 http://www.dssrookie.com/forums/b-font-color-990033-flu-pantec-2500-to-2700-file s-font-b/dans_266_b75-204663.html |
Relevant Product Info
Silver Member Username: Psychmonster
Rhodium Member higher
Post Number: 807 Registered: Jul-06
| Posted on Wednesday, May 14, 2008 - 05:55 pm: |
write failed with this bin... |
Bronze Member Username: Mrgreg
Chatham,
Ont
Post Number: 11 Registered: Dec-07
| Posted on Wednesday, May 14, 2008 - 06:42 pm: |
Dans 266 B75 failed here also |
Bronze Member Username: Cbt911
Post Number: 17 Registered: Feb-08
| Posted on Wednesday, May 14, 2008 - 06:46 pm: |
Write failed, tried twice |
Chatham,
Ont
Post Number: 12 Registered: Dec-07
| Posted on Wednesday, May 14, 2008 - 06:47 pm: |
Same here 2x's |
Bronze Member Username: Terminator2
Toronto,
Ontario
Post Number: 30 Registered: Sep-06
| Posted on Wednesday, May 14, 2008 - 07:00 pm: |
Also here. write failed twice . |
Bronze Member Username: Lupefiasco
Ottawa,
Ontario
Post Number: 29 Registered: Apr-08
| Posted on Wednesday, May 14, 2008 - 07:03 pm: |
Yes.. This bin is a failure i guess.. FAILED FOR ME TOO! |
Silver Member Username: Indopak
Post Number: 104 Registered: May-06
| Posted on Wednesday, May 14, 2008 - 07:50 pm: |
IS THERE A 266 NON PUFF OUT YET? THERE ARE SOO MANY PUFF ONES, WHY NOT NON PUFFS!!!!! |
Post Number: 203 Registered: Nov-07
| Posted on Wednesday, May 14, 2008 - 08:16 pm: |
Please go for PUFF Easy 1.use 2700 to 2500 Loader Select Boot and select Boot60 using 2700 to 2500 loader 2.Use Blacklist loader, select Bin and select Puff bin 253 3.Use Blacklist Loader select Bin and select Puff 266 Very simple n enjoy |
Post Number: 18 Registered: Feb-08
| Posted on Wednesday, May 14, 2008 - 08:35 pm: |
jogi,Why would you post dan_266 b_75 bin without testing it yet, it doesnt work, so now you post another option for people to try! What gives bud, are you bored or something!!! |
Post Number: 206 Registered: Nov-07
| Posted on Wednesday, May 14, 2008 - 08:38 pm: |
Reccommend PUFF as best bet |
Post Number: 19 Registered: Feb-08
| Posted on Wednesday, May 14, 2008 - 08:43 pm: |
Agreed, but whats with your first post? Obviuosly you did not test it! |
Post Number: 207 Registered: Nov-07
| Posted on Wednesday, May 14, 2008 - 08:44 pm: |
Agreed sir |
Bronze Member Username: Eelo
| Posted on Wednesday, May 14, 2008 - 11:01 pm: |
i tried it like several times but its not working before i download the key from ftatalk and know from ftablog i hope it will work |
Toronto,
Ontario
Post Number: 31 Registered: Sep-06
| Posted on Wednesday, May 14, 2008 - 11:08 pm: |
Guys, I have just converted to PUFF. It is simple and you should all do. Refer to the Full kits posted many times in this site. The detailed instruction is excellent and should be followed. |
| Posted on Wednesday, May 14, 2008 - 11:13 pm: |
i dont no how can we chose boot 60 and from where plz help me samehafram |
Platinum Member Username: Lklives
Post Number: 15683 Registered: Jan-06
| Posted on Thursday, May 15, 2008 - 09:33 am: |
Dans B75 converted fix is no good...its his old b75 265 fix that some idiot posted at ftabins and changed the file name...however there is a new Pansat-Fortec B75 converted file released that is working.. |
New member Username: Pops29
Post Number: 7 Registered: Jul-07
| Posted on Thursday, May 15, 2008 - 10:00 am: |
Where´s this bin posted? Anyone can tell me where I can find this kit for switching to Puff |
Platinum Member Username: Nydas
Post Number: 10708 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 10:13 am: |
Dan's apology: dans_new_266_b75 Sorry for inconvenience I zipped it and unzipped good to go This is for those still using b75 files this is clone safe. This is not for LZMA or PUFF Use At Your Own Risk!! Set Default Key and let it A/R. Turn A/R OFF (except Key Code) if experiencing rebooting issues. No need to do a factory setting in main menu if your not having problems. Do one if you are experiencing problems. Attached Files dans_new_266.zip (435.4 KB) The file is available at: http://www.ftatalk.com/showthread.php?t=174908 http://public.box.net/2500_full_kit |
Post Number: 15686 Registered: Jan-06
| Posted on Thursday, May 15, 2008 - 11:13 pm: |
That apology is BOGUS,,and NOT from Dan..some azzhole., probably Nalin the DN mole and rat, posted it ro harm FTA...his original file is the 265, renamed te 266 which doesn't work now! also dssrookie has been posting many BOGUS and virus filled files lately and rumor is that they are sleeping with the AUTHORITIES...so I suggest EVERYBODY stay away from dssrookie.com! Also did ya notice that Nalin WAITED to post here about thos CONVERTED 2500-2700 fix..and trhen recommendd it, which is a BOGUS file..and she claims to be the 2500-2700 EXPERT!...she is here to kill and ruin your receiver and FTA..typical DN mole and rat tactic! if she knew so much she would have warned everybody, and NEVER did! |
Post Number: 10721 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 11:16 pm: |
Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF http://public.box.net/2500_full_kit You must select whether you want to have the old b75 files or PUFF files. If you have b75 boot, you must convert to PUFF boot to use PUFF BINs Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Gold Member Username: The_coders
Post Number: 1202 Registered: Jan-08
Post Number: 15689 Registered: Jan-06
| Posted on Friday, May 16, 2008 - 12:42 am: |
Coder you're another focking useless retard and whiner here..STFU..U act like a lil focking retarded school girl!...and post useless crap all the time...so suck my Dik if ya can't handle the TRUTH!...and go hide behind your h0mo lil computer azzwipe! I've had it with U , nalin, Plymouth and all U faggit USELESS MOUTHAGE lil h0m0's! |
Post Number: 1208 Registered: Jan-08
| Posted on Friday, May 16, 2008 - 12:44 am: |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 2420 Registered: Jan-08
| Posted on Friday, May 16, 2008 - 12:57 am: |
LK Coders is a good guy who are not malicious like you. Return to school and learn how to talk arrogant sh1ter |
Quebec city,
Quebec
Post Number: 2421 Registered: Jan-08
| Posted on Friday, May 16, 2008 - 12:59 am: |
Who is retarded Look the great lk experience: http://forum.ecoustics.com/bbs/messages/2/471885.html Now we know its possible. |
Post Number: 15690 Registered: Jan-06
| Posted on Friday, May 16, 2008 - 09:06 am: |
and we all know your a focking nalin azz kisser or nalin herself...and a rat and mole..and VERY ignorant!..so STFU, and stick to your azzwiping position here...LMAO @ the retard! |
Silver Member Username: King_of_sats
Post Number: 115 Registered: Jan-08
| Posted on Friday, May 16, 2008 - 09:49 am: |
