Thread: Viewsat xtreme pin and bin? |
Bronze Member Username: Louwho31
Post Number: 36 Registered: Nov-05
| Posted on Wednesday, May 14, 2008 - 02:11 pm: |
I just loaded a bin in a new Viewsat xtreme ....DBPSW-080514X.PGM from the Fta head quarters and want to set up my antena and 0000 does not work for the pin. also i'm not sure i picked the right bin..Thanks for any help. lou |
Relevant Product Info
Bronze Member Username: Lupefiasco
Ottawa,
Ontario
Post Number: 28 Registered: Apr-08
| Posted on Wednesday, May 14, 2008 - 03:08 pm: |
It is also at www.ftadoctor.blogspot.com |
Post Number: 37 Registered: Nov-05
| Posted on Wednesday, May 14, 2008 - 04:57 pm: |
I'm sure i have the right file but i can't get past the PI for the antena setup...0000 does not work |
Silver Member Username: Dimwitt
Post Number: 688 Registered: Aug-06
| Posted on Wednesday, May 14, 2008 - 05:01 pm: |
master code Viewsat..: 0937, 3570 |
