Thread: Vs ultra froze wile dl new files |
New member Username: Jmonte
Havana,
CUBA
Us
Post Number: 9 Registered: Feb-07
| Posted on Wednesday, May 14, 2008 - 11:07 am: |
need help, my vs ultra froze as i was down loading latest file with flash drive. dont want to power down what can can i do. any advice is appreciated. |
Relevant Product Info
Gold Member Username: Kirankumar
NO Bashing
Post Number: 2787 Registered: Oct-07
| Posted on Wednesday, May 14, 2008 - 11:43 am: |
remove flash drive |
Platinum Member Username: Nydas
Post Number: 10696 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 12:29 pm: |
You may have to load factory BIN using cable and Loader, and then reload the latest BIN |
Havana,
CUBA
Us
Post Number: 10 Registered: Feb-07
| Posted on Wednesday, May 14, 2008 - 08:07 pm: |
thanks ,i heard froze fix is also good |
Gold Member Username: Way2smart
Www.Desifta.com
Post Number: 1616 Registered: Oct-06
| Posted on Wednesday, May 14, 2008 - 08:12 pm: |
yes it freezes use the cable.....i loaded mine with usb but froze then used cable working fine |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 2400 Registered: Jan-08
| Posted on Wednesday, May 14, 2008 - 09:21 pm: |
j monte Load this mainpg.pgm with cable http://www.box.net/shared/ytdcaz604o After it load last bin Good luck |
Bronze Member Username: Jmonte
Havana,
CUBA
Us
Post Number: 11 Registered: Feb-07
| Posted on Wednesday, May 14, 2008 - 11:37 pm: |
THANKS PLYMOUTH WILL GIVE IT A TRY |
Silver Member Username: Kingofdakingz
Post Number: 258 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 08:16 am: |
thats what i did yeaterday my receiver frozed and what i did was i loaded the latest factory bin and then i loaded the latest bin USING NULL CABLE (NOT USB IT WONT WORK) |
Bronze Member Username: Rtf
Post Number: 47 Registered: Aug-07
| Posted on Thursday, May 15, 2008 - 10:29 am: |
try a hard reboot before you upgrade using USB. |
Gold Member Username: Hawaiian_time
Kanaka freak...
Post Number: 1903 Registered: Apr-06
| Posted on Thursday, May 15, 2008 - 01:56 pm: |
Seems this latest bin for the ultra problem affects some of the receivers. It won't load no matter what you try to do. An older bin will load normally after you flash the ultra with a factory bin. Hopefully a new bin will come out that addresses this problem. |
Quebec city,
Quebec
Post Number: 2406 Registered: Jan-08
| Posted on Thursday, May 15, 2008 - 04:27 pm: |
Warning, if you use factory bin from Viewsat. Thats why you freeze, this bin is corrupt |
