Thread: Viewsat power of problem |
Silver Member Username: Kingofdakingz
Post Number: 255 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 10:20 am: |
i loaded the new bin into my viewsat and it says do not power off since an hour now any suggestions please thanks |
Relevant Product Info
Bronze Member Username: Adirondak
Post Number: 16 Registered: Mar-08
| Posted on Wednesday, May 14, 2008 - 10:26 am: |
I did as normal, thumbs up, so far. |
Post Number: 256 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 10:36 am: |
it worked for my vs but not my cusin should i turn power off like that and do it with the cable ?? |
Post Number: 257 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 11:43 am: |
ITS OK i found the solution. i have to load the factory bin via null cable and then load the latest bin thanks |
