Thread: Conversion 266 BINs - PUFF and b75 |
Platinum Member Username: Nydas
Post Number: 10672 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 12:45 am: |
The first Puff_266 BIN is out. He is new guy on th eblock andI have not tested his BINs yet Tronics PUFF BIN - convert.zip http://www.ftatalk.com/showthread.php?p=1044608#post1044608 |
Relevant Product Info
Post Number: 10679 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 12:57 am: |
bump |
Post Number: 10685 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 07:55 am: |
There are no b75_266 files available yet. There are three PUFF_266 files. http://public.box.net/2500_full_kit http://www.ftatalk.com |
Post Number: 10693 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 12:13 pm: |
Tronics266_PUFF.bin tested and working extremely well. There are no b75 BINs out yet. http://public.box.net/2500_full_kit Download from appropriate section and unzip into a separate directory. Please read the instructions carefully. |
Bronze Member Username: Tito71
Post Number: 24 Registered: Oct-07
| Posted on Wednesday, May 14, 2008 - 06:49 pm: |
Nalin What do you think abot what is mentioned on this website? http://www.ftatalk.com/showthread.php?t=155020 |
Post Number: 10703 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 10:27 pm: |
The general idea is sound. However, I still think that Chancy's puff conversion route was very good. I will take a detailed look. The instructions at the full_kit public load are still very good and have always worked for me. http://public.box.net/2500_full_kit |
Post Number: 10704 Registered: Jun-06
| Posted on Wednesday, May 14, 2008 - 10:28 pm: |
There is only one b75-266 BIN out by "dans" and it is not good. Stay away from it. |
Silver Member Username: Batjc
Post Number: 132 Registered: Aug-07
| Posted on Wednesday, May 14, 2008 - 11:08 pm: |
Nalin just passin by to say thanks to you today i finally converted my b-75 pansat to puff using your guide and is at it 100% thx you very much! |
Post Number: 10710 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 10:17 am: |
Dan's apology: dans_new_266_b75 Sorry for inconvenience I zipped it and unzipped good to go This is for those still using b75 files this is clone safe. This is not for LZMA or PUFF Use At Your Own Risk!! Set Default Key and let it A/R. Turn A/R OFF (except Key Code) if experiencing rebooting issues. No need to do a factory setting in main menu if your not having problems. Do one if you are experiencing problems. Attached Files dans_new_266.zip (435.4 KB) Avaialble at: http://www.ftatalk.com/showthread.php?t=174908 http://public.box.net/2500_full_kit |
Post Number: 10719 Registered: Jun-06
| Posted on Thursday, May 15, 2008 - 11:14 pm: |
As of now there are 4 b75_266 BINs and 7 PUFF_266 BINs available. |
Platinum Member Username: Lklives
Post Number: 15707 Registered: Jan-06
| Posted on Friday, May 16, 2008 - 11:13 am: |
Dsscommunity Forums and LIVE Help Present current Forums and SAFE REPUTABLE ESTABLISHED site...latest files within seconds of release...no bad files ever...FREE..ALWAYS open! http://www.dsscommunity.c*om/forums2007updatednewurl/index.php BTW..we have another brand NEW Forums and a new look and features, now just opening also..in transition from old to new forums ...ALL FREE!...feel free to join and contribute..all are welcome!.. http://dsscommunity.c*om/bbs/index.php BTW...both have LIVE HELP always available too!...FREE! Just the remove the * in the links above...copy/paste into browser..register free like ya did here.. |
Post Number: 10743 Registered: Jun-06
| Posted on Friday, May 16, 2008 - 11:16 am: |
Everything for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF. LZMA version not available. http://public.box.net/2500_full_kit All downloaded zipped files should be unzipped into a separate directory named appropriately. You must select whether you want to have the old b75 files or PUFF files If you have b75 boot, you must use b75 section for b75 BINs or you must convert to PUFF boot to use PUFF BINs If you have PUFF boot, you must use PUFF BINs. If you do not have PUFF BOOT, you MUST first convert to PUFF BOOT using the 640 K 253 version file before installing the latest. Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Post Number: 133 Registered: Aug-07
| Posted on Friday, May 16, 2008 - 12:10 pm: |
hey Nalin i got a question.. i recently converted my 2500 b75 to Puff now my question is... if is possible to convert back to b75? thx in advance |
Post Number: 10764 Registered: Jun-06
| Posted on Friday, May 16, 2008 - 02:48 pm: |
Use the 2700 to 2500 Converter loader of chancy with receiver in "ON" position to load yjr b60 boot - make sure you select boot in the software settings. <b> Don't worry about night rider scroll. Then using the BL updater 1.4 and receiver just turned on from off, install 294T Bin. It will reboot eventually and come to "ON" Now you are ready to install b75 Boot/BIN. Folloow the instructions in b75 section. The above files are in the Revert to 2500 subdirectory of the full_kit_b75. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF http://public.box.net/2500_full_kit |
Post Number: 134 Registered: Aug-07
| Posted on Friday, May 16, 2008 - 06:21 pm: |
ait thx Nalin for your help! thx you very much! |
