Bought Philips DVP 3980 trying to connect to Mitsubishi CS35505. Follow wiring instuctions but unable to get picture or audio. Not sure what channel it needs to be on. HELP!
If so, after making sure your wires are connected correctly, start playing a dvd and then try to find the dvd player by pressing the "source" button in the lower far right corner, or press the "input" button towards the middle of the remote.
