Thread: Lost signal sat locator |
New member Username: Estefania
Post Number: 9 Registered: May-07
| Posted on Sunday, May 11, 2008 - 09:32 pm: |
i lost my signal in dish ... What are the coordinates... just to make sure signal in channel 500 but only like 60% w/ 0% quality on international and pvv and most other channels please help |
Relevant Product Info
Platinum Member Username: Lklives
Post Number: 15663 Registered: Jan-06
| Posted on Sunday, May 11, 2008 - 09:55 pm: |
Use this and find out..reading is a wonderful thing! www.dishpointer.com |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 2750 Registered: Oct-06
| Posted on Sunday, May 11, 2008 - 10:07 pm: |
I'm assuming yo talking about 61.5 - I will make sure yo don't use SW21 for international anymore - Use a coupler instead and make sure yo use TP 12326 as many TPs have already dropped out according to lynsat |
Silver Member Username: Mucho
Post Number: 248 Registered: Dec-07
| Posted on Monday, May 12, 2008 - 09:13 am: |
Estefania You said that you have signal only on channel 500? Is that on Echo 8 @ 110 Pay Per View Guide? |
Post Number: 10 Registered: May-07
| Posted on Monday, May 12, 2008 - 08:01 pm: |
yes on PPV guide on echo 8.10 |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 2341 Registered: Jan-08
| Posted on Monday, May 12, 2008 - 10:02 pm: |
e6cortes9v All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote "NEW" do same thing with all provider on Bev provider 09 07 00 09 06 00 09 05 00 09 01 00 08 01 00 no need to delete keys and load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Thats erase bad data in the box For box who autoroll and lost channels I hope that work Good luck Thanks Reply if it work Please |
Quebec city,
Quebec
Post Number: 2342 Registered: Jan-08
| Posted on Monday, May 12, 2008 - 10:05 pm: |
Your receiver can be corrupt, thats why you lost signal and quality, try it. |
Bronze Member Username: Kayoss
Post Number: 50 Registered: Feb-08
| Posted on Tuesday, May 13, 2008 - 06:38 am: |
Failing that, pick up a "lost" signal locator at Sircut Settee. |
Bronze Member Username: Estefania
Post Number: 11 Registered: May-07
| Posted on Wednesday, May 14, 2008 - 10:04 pm: |
thank you every one for your help i finally got it up again |
