Thread: Sony RDR-VX525 DVD Recorder Default Settings |
New member Username: Bob2701
Post Number: 1 Registered: May-08
| Posted on Thursday, May 08, 2008 - 12:23 pm: |
Hi, I need to know how to set this recorder back to factory default. My wife was in the setup mode and did something and now nothing works. The remote can only turn it on or off, no other funtions. The display says DV or something like that. I can't find my manual and cannot locate one online. TIA Bob |
Relevant Product Info
Bronze Member Username: Ieee488
Post Number: 98 Registered: Dec-07
| Posted on Thursday, May 08, 2008 - 04:20 pm: |
I'm not sure where you looked, but the manual is available for download from Sony.com |
Post Number: 2 Registered: May-08
| Posted on Friday, May 09, 2008 - 12:24 am: |
Thanks, I don't know why I missed it the first time but they did have it. I found that my Recorder was set to DVD 1 and the remote was set to default DVD 3. All is well again. Thanks, Bob |
