Home > Message Board > Home Video > DVD Recorders > Clock/Timer
Author Thread: Clock/Timer
Username: Cav366
Sorry if this has been posted previously,
MSR90D6 Magnavox DVD Recorder out of warranty but never used. Sets up ok and will record manually but when I set the clock it will not run. Has anyone had one of these and had it fixed, What was wrong, can't really afford new one. Thanks. Bob
Relevant Product Info
Username: Plymouth
Quebec city, Quebec
Post Number: 2248
You need to set time clock before and and power off , power on erase preset clock timer, power off, power on and preset your clock timer.
Note: power on-off on front panel
I hope that work
Good luck
Username: Plymouth
Quebec city, Quebec
Post Number: 2249
You must unplug for 1 minutes before do this.
Note: you need to power off for timer working
Username: Cav366
Plymouth;;; Thanks for the prompt reply, I am trying your hint and will reply as soon as I can.
Username: Cav366
Plymouth; I tried the suggestion and it did accept the correct time and I powered off but the next time powered on it still had the new time last entered.
Iguess it's just not running! Any other suggestions ????? Many Thanks BoBLl
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > DVD Recorders > Clock/Timer [ « Previous ] [ Next » ]
