Home > Message Board > Home Video > HDTV Reception > Samsung TX-T2782H
Author Thread: Samsung TX-T2782H
Username: Nhiverson
ok thats my hdtv http://www.amazon.com/Samsung-TXS2782H-Slim-Fit-HDTV/dp/tech-data/B000F2R5MY
i have comcast no set top box just straight cable line im wondering what do i need to do to get this to find hd channels?
Relevant Product Info
Username: Nhiverson
just like to add that my tv has ntsc and atsc but sure it dont have qam if that helps anyone help me out .
Username: Nhiverson
hmmmm thanks for no help thought people checked here rather quuick.
Username: Say_what
Post Number: 20
Well, as your set has no QAM tuner it won't pick up anything through cable. HD over the air (antenna) would seem to be your only option unless you want to get an HD converter from Comcast.
Username: Nhiverson
oh ok so i can get the hd set box and iwill get hd thanks for the help.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > HDTV Reception > Samsung TX-T2782H [ « Previous ] [ Next » ]
