Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through August 12, 2008 > Panasonic TH-42PZ77U
Author Thread: Panasonic TH-42PZ77U
Username: Hoosier_daddy
Post Number: 165
just hooked up this tv it replaced a TH42PX and it the picture does not look as sharp as the other one, it's good but not as good.
I have it through a HD cable box with HDMI going from the box to the TV...
One of the differences I noticed was that you can change the aspect on HD channels on the z where on the X you couldn't. I have it set on full..is that correct?
I know I have it hooked up the same..I took a picture and labeled all the cables..I must say I am a bit disappoined right now.
Any suggestions?
Username: Samijubal
Post Number: 3817
Many people have complained of this, it's the anti-glare screen of the new TV vs the anti-reflective screen of the other TV. If you've got a lot of light in the room, the AG screen is better, if not, the AR is better.
Post Number: 168
Thanks. One other question. When watching some HD shows the black seems to blend in with everything.
IE: while watching 2.5 men two people were standing together with dark suits and I couldn't see any details they were just kind of merged together.
Username: Rysa3
Houston, Texas
Post Number: 342
A couple of things. Like David says, the filtering on the 77u didnt make some folks very happy.
That being said, you should at least try to calibrate the new set using AVIA/DVE or some set up disk.
AS far as the black crush, a lot of folks do better on this issue with component cabling over HDMI, something I am sure you dont want to hear, since component wont pass 1080 signal from, for instance, a blu ray player due to copy protection codec imbedded in the hi def signal.
also check the settings on the HD-cable box if present. so if its a hi def channel set it to 1080, but if its a standard def channel set it to 480, and if its espn might try 720 or 1080 and see which is best, if either.
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through August 12, 2008 > Panasonic TH-42PZ77U [ « Previous ] [ Next » ]
