Home > Message Board > Home Video > Satellite TV > Archive through June 21, 2008 > NEW KEYS (Part-2 continuation thread) > Archive through April 10, 2008
Author Thread: Archive through April 10, 2008
Username: Nydas
Post Number: 9845
First time round you have to go through the full ritual of setting up the receiver after loading the BIN and then scanning.
Later on, much of the headache can be avoided, if you have channel master - a piece of software in your computer to save the channels and your full setup.
So for subsequent BIN loads including changing from one BOOT to another, You save the setup using channel master, load the new BIN, and then install your save channel setup.
Reading and understanding new software takes time, but it is worth it.
The only thing that Channel Master does not tell you is that although you use the same cables for connecting, you have tell channel master that you have "Pansat 2700 or 3500"
Relevant Product Info
Username: Nydas
Post Number: 9848
M. Shah: I saw an earlier post of yours where you said you could not find a file and loaded another.
YOU CAN'T DO THAT except where permitted. The only thing permitted is
1. Selection of Background picture
2. selction of latest BIN WITHIN THE GROUP. This means that if you see b 7 5 scrolling you use a b75 BIN. If you see PUFF scrolling you use a PUFF BIN and if you see PUFF. twice and a stop, it menas it is a LZMA boot and you have to use LZMA BIN.
To cross these boundries you have to use special tools and methodologies designed to change the bOOTs and BINs.
The worst thing you can do is to say, "I could not find this file, so I used the other file" That is absolute NO- NO
Username: Ather_da_don
Mississauaga, Ontario
Post Number: 455
Whoever has not made the PUFF transfer, can still get the b-75 261 bin at www.dishkeyz.tk
Post Number: 456
There are also links on the side which give you other files!
Username: Valinex
Post Number: 20
If there are no more bins coming for cs 4000, 5000 & 6000, then support is gone. Except I do not understand why no one else comes with a bin, other than the manufacturer of these units.
Post Number: 457
Valinex... I'm not too sure, but i think only the support team can get the files! ONLY THEM..,
Username: Mshah2006
Mississauga, Ontario
Post Number: 114
My converted Fortec Lifetime Ultra (FLU) receiver has gone blank. No signs of life in the display. It occured after working for few minutes just after loading Bin 261 for b75. Is there a solution to my receiver or it has gone kaput.
Username: Mshah2006
Post Number: 115
Hi Nalin... On my second receiver I only loaded b75 bin #261 and same thing happend with that receiver too. It worked for a few minutes like 20 minutes and then went blank with no lights on the receiver display. Do you think it is still a software problem or the receivers are gone for ever? Please suggest. Thank you.
Username: Valinex
Post Number: 21
Dr. Dre, if it is the support group that can issue new bins, they would continue to issue it for the cs 4, 5, & 6000. But if the support group is paid by the manufacturer to force the purchase of newer models, then this will point the finger at the manufacturer. If you know what I mean.
There are older units than the cs that are still getting their new bins.
Username: Parathesi
Post Number: 36
I have converted my panst 2500 clone receiver to puff.Is there any way to revert puff conversion to b75 . or original b60 boot. If anyone knows can you please post the method
Username: Mshah2006
Post Number: 116
I need a new receiver which is the best and still under $200?
Username: Mshah2006
Post Number: 117
Some body give suggestions on buying new receiver. What should be looked at before buying a new receiver?
Diamond Member
Username: Lklives
Post Number: 15181
1000 posts here with the answers..
get a USB ready receiver
conaxsat mini
captiveworks 700
sonicview 4000
viewsat ultra
or get a Nfusion with IKS, internet self updating..
Username: Nydas
Post Number: 9880
Selling receivers now?
Post Number: 458
LK is write. USB ready receivers are a lot better. But... FOR dish keys and files go to www.dishkeyz.tk
Username: Mshah2006
Post Number: 118
LK...Thank you for suggesting receivers. I hope they will not become obsolete too soon.
Username: Mshah2006
Post Number: 119
What is the real advantage of buying Nfusion NOVA over other receivers. I see in a comparison where the processor speed for NFusion is only 120MHz compared to Vewsat Ultra which is 200MHz and Conaxsat is 200MHz Captiveworks 800s is 160MHz. and so the memory for NFusion is only 16MB compared to others which is 32 or 64MB. Nfusion does not have Highspeed USB where as SonicView400, Conaxsat and Captiveworks 800s all have high speed USB.
Username: Rekman
Mntl-Quebec-...
Post Number: 358
hi Nalin... bin for cools*t is out or not???
Nalin.... if i was supposed to buy a new receiver...... which receiver would you advice me to buy???
i am planning to buy one bcoz the cools*t is always always the LAST to releaase bin.... ...
advice please...THANKS
Username: Rekman
Mntl-Quebec-...
Post Number: 360
Username: Plymouth
Quebec city, Quebec
Post Number: 1524
Hi MKM how are are you this afternoon
Username: Plymouth
Quebec city, Quebec
Post Number: 1525
Friday i buy a CW600s premium
Cheap to buy and work fine
Buy it, colsat 5000 dont have good support now
Username: Mshah2006
Post Number: 120
MKM... Buy CaptiveWorks700S or CW800S you will be fine. They will cost $120 to $140 since I have already done some research.
Username: Leidy08
Post Number: 56
Hello, I need some help. I converted aFortec Start to a Pansat 2700 it was ok I was watching the TV but them the receiver when OFF, Can some one tell me what do I need to changed any receptor.
Username: Nydas
Post Number: 9896
Margarita: People at this forum do not like multiple posts with a level of emphasis you have displayed.
I have replied you elsewhere.
Username: Valinex
Post Number: 22
can cs 4000 be cloned to something else ?
Username: Nydas
Post Number: 9904
Apparently you can first jtag convert it to Skyview and then on to CaptiveWorks.
If i find confirmation somewhere i will post it.
Diamond Member
Username: Lklives
Post Number: 15210
Nalin and all your aliases....U do NOT know about FTA...and are just a Dishnet official/mole here working with Ecoustics, monitoring the members and FTA news...get out of this thread, and site!
Anybody who listens to you deserves the $4000 civil suit that U will have brought down on them..
Username: Lkloves
Post Number: 10
I posted as above only to hurt Nalin and damage his reputation.
He is usually a very good poster and advisor.
I, LK, wish to apologize
Username: Jagga
Post Number: 54
Hi,
I just purchased a VS Ultra. I need your help to get started.
1. I loaded the recent bin from TotalFTA site "PFTAUSW-080404U.PGM" to my usb drive.
2. Plug the USB to the receiver.
what do i have to do next, to get BEV and DN chenels
I tried doing blind scan but not getting anything. its says auto rolling processing? Also tried hard boot after blind scan. no use at all. can anyone please explain step by step after i load the bin into reciever.
Thank you,
Username: Plymouth
Quebec city, Quebec
Post Number: 1546
Jagga you need to setup all sat
What is your system like dish switch and LNB?
Username: Usha
United States
Post Number: 15
Nalin,how are you?...I would like to get your option about what receiver i should buy,my old receiver doesn't work and i need something that is good and easy to operate and program,please advise me on this situation and i would like to say to LK,get off Nalin back,he is doing a great service to alot of people. Thanks
Username: Gregraf
Post Number: 112
Go ahead take advice from Nalin youll be sorry
Username: Mshah2006
Post Number: 121
Usha.. You won't be sorry if Nalin suggests you a dependable receiver.
Username: Wkb
Post Number: 30
Hey people, any news about cs 6000. It is very frustrating.
Username: Metallica
Post Number: 569
CS 4000..5000 and 6000 nothing.
i think it time to get something new.
Cooolsat SUCK!
Username: Wkb
Post Number: 33
Any suggestions of receivers, Metallica?
Username: Nydas
Post Number: 9918
Usha: This is my first reply to you. There are some clever people who not only copy my name and attempt to give my name to their advice, but are clever at hiding it by then erasing the post so that only the current audience receives the post.
You got one such post from some idiot.
Normally, I would strongly suggest Sonicview 4000 at about $150.
However there is one new problem in site, i.e. both Bell and Dish have started new encryption called Nagravision 3. this one has been around in Europe for over 4 moths now and has not been deciphered. Bell is already distributing new cards and Dish is still in the testing phase.
This could mean a long blackout and your $150 investment could be sitting idle on top of your TV as a support for a flower vase.
CaptivWorks has had very good support and the 600Premium is selling for about $50-65. It does not have a USB drive input. But it will get you by for the next 4 months and you will also be able to look at the HD receivers as the prices come down and the technology matures, so that 3-4 months down the road, you might invest in a HD receiver that will receive whatever you need to receive. You will definitely have a $100 saving and a better HD receiver in 3 - 4 months.
For the very same reasons against investing a lot now , I am rejecting investment in Nfusion (about $250) as of now although that is otherwise a very wise move.
Username: Parathesi
Post Number: 37
Nalin , You gave a very good picture of receivers. Thanks for the advise. Who ever want tyo buy a new receiver. Follow Nalin's advise.
Username: Joe123xyz
Post Number: 41
Hi guys, please advise...what do you think about Conaxsat Duo? Thanks.
Username: Mshah2006
Post Number: 122
Hi Nalin... I ended up buying NFusion. Do you think I will need any bin file to start with or it has a factory bin installed? Or please direct me to a site where I can get information on installing new NFusion receiver. I don't see any files listed for NFusion on diffrent sites which normally offer new files. I would really appreciate your help in this matter.
God Bless You.
Post Number: 459
Conaxsat is allright, But joe, go for recievers with better support such as sonicview or viewsat. Files and dish keys are always at www.dishkeyz.tk
Username: Nydas
Post Number: 9932
M. Shah: Ask Sada in the main forum. He will guide you through the installation. it is not as straight forward as some receivers.
Username: Mshah2006
Post Number: 123
Hi Nalin... I don't know where should I address Sada. If I ask the same information from Sada in this forum, I want to know if I will get any response? Your guidance is still needed please.
Username: Mshah2006
Post Number: 124
Hi Sada... Nalin has referred me to you for help... I ended up buying NFusion. Do you think I will need any bin file to start with or it has a factory bin installed? Or please direct me to a site where I can get information on installing new NFusion receiver for the first time. I don't see any files listed for NFusion on diffrent sites which normally offer new files for all other receivers. I would really appreciate your help in this matter.
God Bless You.
Username: Rekman
Mntl-Quebec-...
Post Number: 361
hi PLYMOUTH & M SHAH......
thank you for replying.. but now am confused... lol !!!... each one is advisin different receiver...
tll me which is the best best best best one.......
thanks
Username: Plymouth
Quebec city, Quebec
Post Number: 1569
MKM how are you tonight
you can buy CW 700 or a VS ultra
2 good receiver with good support
each one have USB port.
CW is cheaper to buy
Ultra is easier to setup
MKM choose between this two box
Username: Rekman
Mntl-Quebec-...
Post Number: 363
thanks
Username: Mshah2006
Ontario
Post Number: 126
MKM Follow what Plymouth is saying. I have purchased NFusion and am unable to setup yet. I need some body who has purchased NFusion and has completed setup.
Username: Rekman
Mntl-Quebec-...
Post Number: 364
am doing very well plymouth... its only tv program keeping me upset......
how about you????
you bought another receiver...
wat is CW700???..
Username: Mshah2006
Ontario
Post Number: 127
Hi Every body or the Guruz on this forum:
I have purchased NFusion I need help to install NFusion for the first time. Do I need any bin file to make it work? or there has been no bin file releasd for this receiver? If there is one please let me know where to get it. I would reeally appreciate your help.
Thank you.
Username: Metallica
Post Number: 573
M. Shah ask Sada he know a lot about NFusion he will help you out..
Username: Plymouth
Quebec city, Quebec
Post Number: 1576
MKM i buy a CW600s premium
But i have 2 laptops for download
without unplug this box.
The CW700 have a USB port, more easy for download from a PC
I'm very fine
Username: Plymouth
Quebec city, Quebec
Post Number: 1577
Mr Shah
Start a new thread and ask help to Sada the NFusion pro like African say
Username: Rekman
Mntl-Quebec-...
Post Number: 365
