Thread: Samsung picture problem! |
New member Username: Bcb97
Starkville,
Ms
Post Number: 1 Registered: Apr-08
| Posted on Wednesday, April 23, 2008 - 01:11 am: |
Everytime I turn my tv on now when it hasn't been on for a while, a half and half picture is on. On the left side the picture is clear and normal but on the right side the picture is a milky foggy color over the picture. After about ten minutes or so it goes away and is normal again. I also feel like my tv isn't as clear as it used to be. I've been given the run around by Samsung on the phone and they keep telling me a tech will be contacting me but no luck yet. My warrant ends soon and I need this fixed now!! |
Relevant Product Info
Bronze Member Username: Levelzero
Post Number: 22 Registered: Aug-07
| Posted on Wednesday, April 23, 2008 - 12:04 pm: |
See if you can find a nearby Samsung approved repair shop to come out and take a look at the set before the warranty runs out. When you call, just ask if the shop do warranty repair work for Samsung. |
Gold Member Username: Samijubal
Post Number: 3802 Registered: Jul-04
| Posted on Wednesday, April 23, 2008 - 01:19 pm: |
As long as the problem is documented before the warranty expires, you're good. The repairs don't have to be done before the warranty expires. Call Samsuck and get a case number that you can reference if the warranty expires. |
Starkville,
Ms
Post Number: 2 Registered: Apr-08
| Posted on Wednesday, April 23, 2008 - 04:29 pm: |
The problem is that I live in a small town thats not around a repair center thats in their archives. So the repair center would have to drive 30 min to and hour just to look at my tv. I do have a case number also. I just hope its not a major problem. |
Post Number: 3804 Registered: Jul-04
| Posted on Wednesday, April 23, 2008 - 07:20 pm: |
I had a repair guy drive about 40-45 miles to work on a Sony TV I had. Sony was pretty easy to deal with. I don't know about Samsung. |
