Home > Message Board > Home Video > Satellite TV > Archive through June 21, 2008 > NEW KEYS (Part-2 continuation thread) > Archive through April 04, 2008
Author Thread: Archive through April 04, 2008
Username: Ather_da_don
Mississauaga, Ontario
Post Number: 443
C00LsSAT BIN and all others out at www.dishkeyz.tk
Relevant Product Info
Username: Dzejlana
Post Number: 9
hello everyoneee
i really need ur helppp
i have a pansat 2700A
and when i turn it on all i see is lines dancing back and forthh
what factory bin do i need to use to clear it all out
please help i been havin this problem for long time i searched the net for factory or fix i got nothing...
anyone have any ideas or step i need to do to fix my pansat 2700A
thank you so much and god bless you all
Username: Dzejlana
Post Number: 10
hello everyoneee
and wen i turn it on all i see is lines dancing back and forthh
Username: Jasoradicalcool
Toronto
Post Number: 23
dzejlana
go to http://www.pansatusa.com/home.htm try it out im not really sure
Username: Swredneck
Halifax, N.s.
Post Number: 60
can t seem to get 401 ppv any body else havin this prob!!wmania 24 !a no go !??anyone else gettin it>?
Username: Plymouth
Quebec city, Quebec
Post Number: 1393
Jerry which receiver?
Work fine on VS Ultra
Username: Plymouth
Quebec city, Quebec
Post Number: 1394
Nimiq 1,3 # 401 12632 20000 V 5/6
V5922
A5923
P5922
Username: Mshah2006
Mississauga, Ontario
Post Number: 101
DN is up and runing on most Receivers.
Post Number: 444
YUP and so is BEV. IF you still need to find the files, go to www.dishkeyz.tk
Username: Valinex
Post Number: 10
Nalin,
I just purchased a VS Ultra, to replace my CS4000. I need your help to get started.
1. To load bin I use loader 2.1
2. Do I have to use the software for a virgin unit first ?
3. There are bins 131 & 132. What are they ?
4. Then there is the last bin 080327.
5. How do I change keys manually. In the CS I pressed 8282. How is it done in VS
Username: Plymouth
Quebec city, Quebec
Post Number: 1414
Valinex i'm not Nalin but i can help you on Viewsat my speciality.
1)no need to use loader because you have a USB port( if the stb is dead only you need loader)
2) no you dont need it
3)these 2 bin are factory bin no need it now
4)Go to ftahq this bin is good now and download and unzip it and load on USB key, put your USB key in front of stb
with remote go to Menu
System information
receiver upgrade and select USB choose the pgrm pres OK
Now wait the receiver come to " on"
After you need to setup your sat in menu and do a autoscan and save.
5)"change keys" press menu
user settings
code menu
in CAS with left arrow select Nagra and choose the good provider you went.
No need to change keys the autoroll work fine thats take + - 5 minutes to autoroll
Good tv guy
Username: Valinex
Post Number: 11
Thanks Plymouth
Username: Rekman
Mntl-Quebec-...
Post Number: 354
Is BIN for cools*t 5000 out????
THANKS
Username: Plymouth
Quebec city, Quebec
Post Number: 1416
Hi MKM how are you
I have your bin my friend
But i dont know how give to you
Username: Rtejada
Post Number: 7
Nalin, can you help me. I have a ViewSat Ultra and have been trying to do a blind scan, but after going through all the channels selection, it wont finish. It does not open the DO YOU WANT TO SAVE CHANGES window and goes back to the initial starting point when it finishes. What should I do?
Thanks
Username: Rekman
Mntl-Quebec-...
Post Number: 355
lol PLYMOUTH....
GIVE me the add.. then i will go on the site to download it...
tu peut tu me le donné lol.. !!!...C'est beau..
am waiting .
thanks
Username: Plymouth
Quebec city, Quebec
Post Number: 1426
MKM this bin is not good
Username: Plymouth
Quebec city, Quebec
Post Number: 1427
Raul Tejada I,m not Nalin but i can help you
When you do a blind scan and it return without ask to save it, thats because blind scan dont found new channel.
Why you went to do a blind scan?
Username: Rekman
Mntl-Quebec-...
Post Number: 356
PLYMOUTH... the 170 BIN i have it on my receiver.... i thought there is a new one out... because my receiver saying SCRAMBLE CHANNEL since Friday 29 March....
so if the bin is the same 170 as 10 march... so wats the problem then???.... why scramble channel......
PLEASE HELP
Username: Halo
Toronto, Ontario
Post Number: 450
new dish keys at www.dishkeys.co.nr!
Username: Plymouth
Quebec city, Quebec
Post Number: 1436
MKM sorry this bin is a old one
One friend give me this one
I search for one again and no result
Sorry my friend
Username: Rekman
Mntl-Quebec-...
Post Number: 357
OK... thanks indeed... t'es bein bein gentil... lol !!!!
we shall wait for the bin then.. may b 2morrow will be out... thanks
Username: Nydas
Post Number: 9706
There are no new C00LSAT BIN FOR 4000 5000 OR 6000.
Never on a Sunday or even on a Monday?
Username: Rtejada
Post Number: 8
Thanks, Plymouth
Post Number: 445
All the new keys and bins at www.dishkeyz.tk
Username: Parathesi
Post Number: 35
No New Bins Out yet For Coolst 4000 , 5000 ,6000
The latest is bin 170. It is not working . We Need 171. It is not out yet.As nalin said not on sunday or monday.May be not on tuestday too. Wait..Wait..
Username: Valinex
Post Number: 13
Plymouth, I had uploaded on my computer my channel list from the CS4000. Can I download this list to the Viewsat ? How ?
Username: Valinex
Post Number: 14
Bins for cs 4000, 5000 & 6000 come out on Thursdays, and go out on sundays.
Username: Plymouth
Quebec city, Quebec
Post Number: 1442
Valinex sorry but i know nothing on colsat.
I just try to help MKM
Start a new thread for help.
No need to download it in viewsat
the channel list come by itself with bin
Thanks
Post Number: 446
New keys for BEV:
Bell ExpressVu (0901) [Last update: Tue. Apr 1, 4:27 PM
86: 8F 54 62 E2 B8 3C 38 C8 D3 23 BA 9C A6 DE 56 7E New
96: BA 34 5F C9 5F 7B 2E 24 0A 5A 34 F4 6E 12 38 F5
from www.dishkeyz.tk
Username: Valinex
Post Number: 15
I got my viewsat ultra, loaded the new bin, scanned. Then it froze. I tried a hard boot (switch off at back), then turned it on again, and it either did not turn on, or if did it showed AA:AA (really it was 88:88, defective , the line at the bottom does not show).
Is my new unit gone ?
Username: Plymouth
Quebec city, Quebec
Post Number: 1446
Valinex now you need the loader:
In your package box with receiver is furnish a cable RS-232 you must download factory bin with the cable from your computer .
Go to: <http://viewsatusa.com/support.htm>
download this 2 files:
PVR Loader v11 - Firmware Updater ( Serial)you install this one on computer
VS2000 ULTRA Factory Bin File - V132
for download with the loader in your receiver
close rear switch on receiver
open program take file v131
clic to download in receiver and a second after
switch on
the transfert take 5-10 mins
you must see 0000
download the last bin with USB
Good luck
Username: Valinex
Post Number: 16
Plymouth, I have downloaded the loader, V132 & V131.
When I turn my stb on there is no light whatsoever in front. Only the small red light at the back.
I tried with the loader, first with V132, FROM PC TO STB, I had the stb OFF from the rear, then turned it on a second after the download. It kept showing "Resending ZRQINIT.." then showing "Frame type 255 60 Id 0c81", then going back to "Resending ZRQINIT" and so on. Is this O.K. with no end ?
Username: Halo
Toronto, Ontario
Post Number: 452
Latest keys at and info at www.dishkeys.co.nr
Username: Plymouth
Quebec city, Quebec
Post Number: 1449
Sorry Valinex i'm come back
ZRQINIT is adress problem with port
restart your computer and in loader program go to tool and set it to port com1 and retry it
Post Number: 447
Latest Dish keys and files at www.dishkeyz.tk
Username: Sidthekid
Post Number: 86
you can find new dish keys at www.ftakeys4u.blogspot.com
Username: Valinex
Post Number: 17
Plymouth, the loader is set at port com1.
Is it normal that I do not get any light on the front, no 0000 or anything else ?
Username: Plymouth
Quebec city, Quebec
Post Number: 1451
No it's not normal, i think your new box is corrupt.
Try to synchronized the operation
when you turn on receiver and send loading.
That can make many try.
If the back light is on, youre box is good.
Username: Valinex
Post Number: 18
Plymouth, thanks for your help. We have a proveb that says "give the bread to the baker, even if he eats half of it".I am giving my receiver to a technician to fix it. It is a brand new one. I just hope it is not a clone.
Username: Plymouth
Quebec city, Quebec
Post Number: 1453
Ouuupsss i hope for you.
Valinex
Maybe try with another computer.
Good luck guy!
Post Number: 448
new dish keys also at www.dishkeyz.tk
Username: Halo
Toronto, Ontario
Post Number: 453
latest keys at www.dishkeys.co.nr!
Username: Sunil59
Post Number: 30
WHAT ARE THE NEW KEYS FOR DISH PLS HELP
Username: Metallica
Post Number: 547
new keys..save it for future use.
http://www.tvkeyz.com/
Post Number: 449
latest keys at www.dishkeyz.tk
Username: Skeptik
Artica
Post Number: 51
DN DOWN....///
Username: Swredneck
Halifax, N.s.
Post Number: 61
are we all down again>?
Username: Swredneck
Halifax, N.s.
Post Number: 62
i guess so lol!!
Username: Fta67
Manitoba Island
Post Number: 13
Yes, DN and BEV are down, wait for new bin files for your device.
Username: Mshah2006
Post Number: 103
Yes, DN is down for the last 2-3 hours.
Username: Mshah2006
Post Number: 104
Don't worry. Nalin will come up with a solution soon as usual.
Username: Halo
Toronto, Ontario
Post Number: 455
New update and new files will be posted at www.dishkeys.co.nr...keep checking for updates
Username: Eelo
hey guys is star one n star plus is working while the DN is down
Username: R1010
Post Number: 145
yes
