Thread: Panasonic T V |
New member Username: Papadon14
Red bluff,
Ca.
Post Number: 1 Registered: Apr-08
| Posted on Friday, April 04, 2008 - 10:34 pm: |
I bought a used 28 inch panasonic for the bedroom, works just fine exceptin the lower right corner is a pip screen 6 inches square no matter what I do I can't turn it off, it is always same channel as tv is set to. Is there anyway to turn it off? The original remote is not available, has a programmable remote also no manual with it. |
New member Username: Pappyson
Winchester,
Tn
Post Number: 1 Registered: Jan-09
| Posted on Wednesday, January 07, 2009 - 07:37 pm: |
I'm trying to get my TV to work with my Home theater system when I'm not watching DVDs |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 574 Registered: Jun-05
| Posted on Thursday, January 08, 2009 - 02:03 pm: |
James start your own thread. We will need more info to figure out your problem. Model numbers of all equiptment is a good start. Try hooking up the cable box audio out to the receiver. |
