Home > Message Board > Home Video > Satellite TV > Archive through April 03, 2008 > Viewsat Ultra Missing Channels
Author Thread: Viewsat Ultra Missing Channels
Username: Vansuram
Can some one help me here .. I have View Sat ultra 2000 I have good signals on echostar 3 (61.5) but i dont get any of the indian channels when i do a autoscan or blind scan
thanks
Relevant Product Info
Username: Plymouth
Quebec city, Quebec
Post Number: 1468
Suresh go to channel scan and delete 61.5W sat and rescan.
If not work, do a factory default and load last bin.
rescan all sat.
Good luck
Username: Metallica
Post Number: 549
Morning Plymouth.
you're up early today bubby.Upload
Username: Plymouth
Quebec city, Quebec
Post Number: 1470
Goog morning too
Like all week days + - 6:00
Username: Mucho
Post Number: 173
Suresh
Do a TP scan only on the TPs that
your missing Indian channels are on.
Username: Kingofdakingz
Post Number: 204
do as plymouth said
Username: Vansuram
I tried what plymouth said and i still cannot see any indian channel .. I get good satellite signals for 61.5 should i try a different dish like echostar 7 ?
Help would be greatly appreciated
Username: Kirankumar
NO Bashing
Post Number: 2298
Suresh
do not do blind scan on viewsat ultra.only autoscan
if you post your antenna settings i can help,because you don't need to mess with anything else
Username: Plymouth
Quebec city, Quebec
Post Number: 1480
Suresh you need heavy duty Solution
try it:
All viewsat box
"Write your sat info before"
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
"NEW" do same thing with all provider on Bev provider
09 07 00
09 06 00
09 05 00
09 01 00
08 01 00
no need to delete keys
switch off 10 secs on back panel
"New" do a factory default
and load last bin for your box (from dsstesterDOTcom)
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll, freeze and search signal
Do setup on each sat and auto scan on each sat after for recover all channel
"Dont do a blind no need"
"Dont load factory bin"
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Reply if it work
Please
If these dont work look your switch, cable RG-6 and LNB.
Maybe you need to realigned your dish.
You have all for recover this problem now.
Username: Vansuram
Thanks African
Assuming EchoStart 61.5 has got all the indian channels ..
Here are the setting i have
Sat --> Echostar 2 61.5
LNB -- ON
LNB Type - OCS-DP
LNB Freq 11250
22khz -- off
TPFreq -- 12297
DisEqc1.0 -- none
Motor -- Off
SW - none
I have only one dish ( super dish) from which i get good signals for all echostar satellites
Username: Plymouth
Quebec city, Quebec
Post Number: 1482
Suresh your setup is OK
NO Bashing
Post Number: 2300
Suresh,
assuming you have only one satellite and no switch,this is what i want you to do
1. write down your settings
2. do factory reset
3. power box off and on from back
4. go to antenna settings and bring up
61.5 and adjust settings
5. change the setting for TP freq from
12297 to 12326
6. assuming you have no other dish change
lnb type from ocs-dp to single or
standard and see if quality gets
better.but do # 5 before doing this
7. save settings and do auto scan
you should get all channels
post results please
good luck
Home > Message Board > Home Video > Satellite TV > Archive through April 03, 2008 > Viewsat Ultra Missing Channels [ « Previous ] [ Next » ]
