Home > Message Board > Home Video > Rear Projection TVs > Adjust Horizontal Position on WS-5590...
Author Thread: Adjust Horizontal Position on WS-55905 V16 chassis
Username: James_aguirre
I have a WS-55905 (uses the V16 Chassis) The picture is shifted slightly to the left in HD and I would like to center it.I have the Technical manual and have access to the menus, but I can not figure out which function to adjust. I thought changing the HPOS setting in PTC Logic would do it, but it did not appear to change, so I did not save it. Is that the right funtion to adjust? It is currently set at the default of 203, if I want t shift it about 3 inches what would be a good starting point.
James
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > Rear Projection TVs > Adjust Horizontal Position on WS-5590... [ « Previous ] [ Next » ]
