Thread: Pansat 2500a *** dead *** |
Bronze Member Username: Dnvrguy
Post Number: 27 Registered: Nov-05
| Posted on Sunday, March 23, 2008 - 08:06 pm: |
hi all, i probably killed my receiver pansat 2500a, coz the display keeps showing P U F F forever so is there anyway to convert back to original pansat 2500a without jtag like a factory bin or something . i will really appreciate it. thnx all |
Gold Member Username: Nydas
Post Number: 9432 Registered: Jun-06
| Posted on Sunday, March 23, 2008 - 08:09 pm: |
It is not dead. You now need to load the latest PUFF BIN. There is a huge set of instructions and files if you want to be a bit patient and read. For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 boot or PUFF boot or PUFF_LZMA boot and matching BINs http://public.box.net/2500_full_kit Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Post Number: 28 Registered: Nov-05
| Posted on Sunday, March 23, 2008 - 08:12 pm: |
thnx Nalin for ur help, i did all the instructions says , when it does not work i start downloading anything could help , like boot60 nad so , i know even now what file it got, it says just P U F F keeps running from the left to the right plz what can i do ? thnx |
Post Number: 9434 Registered: Jun-06
| Posted on Sunday, March 23, 2008 - 08:40 pm: |
LOOK AT THIS: http://www.ftatalk.com/showthread.php?t=150839 |
