Thread: Puff_LZMA Conversion |
Silver Member Username: Dure
Mississauga,
Ontario
Post Number: 187 Registered: Jun-06
| Posted on Sunday, March 23, 2008 - 05:33 pm: |
I have converted me FLU to PUFF and is working perfectly. Now there is a new thing PUFF_LZMA boot. Have I got to convert again to this PUFF_LZMA. What is this LZMA conversion. Again Nalin or somebody pl |
Silver Member Username: Metallica
Post Number: 420 Registered: Jan-08
| Posted on Sunday, March 23, 2008 - 05:38 pm: |
Viswaa please help this guy he try to convert to Puff but got stuck...Thanks http://forum.ecoustics.com/bbs/messages/2/464425.html |
Bronze Member Username: Dnvrguy
Post Number: 25 Registered: Nov-05
| Posted on Sunday, March 23, 2008 - 05:47 pm: |
i have convetred pansat 2500a to puff with jvvh_255 and i load jvvh_258, the display show p u f f and got black screen i switched off and on shows the same thing , so i did load again jvvh_255 the display shows again p u f f and gone plz help |
Gold Member Username: Juancho
De los cerros mas alto...,
BINDURABLE.
Post Number: 2700 Registered: Dec-06
| Posted on Sunday, March 23, 2008 - 05:56 pm: |
you have to load Jvvh_253_CanAm (PUFF) 640 kb) this is the converter bin file,no 254 ,after the PUFF knight riders use Blacklist loader 1.4 and load jvvh-258-nkk-puff.bin. hit 8282 set default keys and wait for A/R |
BINDURABLE.
Post Number: 2701 Registered: Dec-06
| Posted on Sunday, March 23, 2008 - 06:06 pm: |
I have the direct links to 253 casnam bin and 258 nkk Puff bin. do you want it? |
Post Number: 26 Registered: Nov-05
| Posted on Sunday, March 23, 2008 - 06:18 pm: |
well to convert from b75 i used 253canam and after i loaded the bin jvvh 255 last week and today i did load jvvh 258 and that thing happened , plz help, is there anyway to convert back to a basic 2500a thnx |
BINDURABLE.
Post Number: 2703 Registered: Dec-06
| Posted on Sunday, March 23, 2008 - 06:38 pm: |
use other 258 PUFF bins , after the first P load JVVH-258-PUFF bin. here is a good bin.posted for who modds the NKK bins. go here y look for Nikk Mty Post #1847, this bin will resolve all your problems. or you can use boot60 and start over. or use Lzma_boot and convert to Lzma. I have both boots and direct links to nkk bins, go here for bin 258 nkkhttp://forum.ecoustics.com/bbs/messages/2/464036.html |
Gold Member Username: Nydas
Post Number: 9424 Registered: Jun-06
| Posted on Sunday, March 23, 2008 - 07:35 pm: |
For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 boot or PUFF boot or PUFF_LZMA boot and matching BINs http://public.box.net/2500_full_kit Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
BINDURABLE.
Post Number: 2707 Registered: Dec-06
| Posted on Sunday, March 23, 2008 - 07:59 pm: |
I don't follow the instructions that said: If you "STB has Boot B-75 or Boot60 you don't need to load this boot". As most of the receivers that I do and do not load the boot 60 for converter to Puff often I have to do it because the STB's are stuck on the F or rebooting without stops, I said this because I have to changes my STB from PUFF to Lzma and viceversa for testings,for that reason I allway recommend to load boot60 . anyway they are coders or modds, no testers. |
