Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Need serious help with puff plz!!!!
Author Thread: Need serious help with puff plz!!!!
Username: Bte
Post Number: 18
hi guys i need serious help i was converting my 2500 to 2700 clone to PUFF and i have been stuck on (F) forever plz help asap!
Username: Bte
Post Number: 20
plz help
Username: Juancho
De los cerros mas alto..., BINDURABLE.
Post Number: 2702
the F. mean yoyu have now a PUFF receiver.
now use Bl loader 1.4 and the when first F
shows load jvvh_258_Nkk_Puff.bin. here it is
posted for who modds the NKK bins, look for Nikk Mty post#1847 here.http://forum.ecoustics.com/bbs/messages/2/464036.html
Username: Bte
Post Number: 27
thx for reply, now i loaded the bin. puff flashes twices and stays on f for 10 seconds and restarts.
Username: Bte
Post Number: 28
the reciver never comes to "ON" just stays on F now plz help
Username: Juancho
Post Number: 2704
then you have to come back to 253 Canam 640 kb bin
and start over again.or just load a chanel list if you any ,using Gtromloader 27.02
load it . are you sure that you have only F
no F. the last one mean you have to load lzma bin..tell which one do you load , I will post the boot
application/x-zip-compressedUpload
Boot60.zip (13.6 k)
Lzma-boot(PUFF.).zip (22.4 k)
Username: Bte
Post Number: 30
yes i checked agian and it only F and i tried uploading channel list using channel master it doesnt work.
Username: Juancho
Post Number: 2705
then you have to load boot 60 with loader converter to 2700 . when the knight riders(----) no turn off stb, use nikk 258 nkk PUFF bin and load using 1.4 loader
Username: Bte
Post Number: 31
u mean re-install puff
1) Using 2700 to 2500 loader: use boot60 with (boot not bin) then download
2) using blacklist updater 1.4 download jvvh fortec-pansat canAm puff 253(640k) bin
3)download nikk 258 nkk PUFF bin
right??
Username: Nydas
Post Number: 9422
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included. Either b75 boot or PUFF boot or PUFF_LZMA boot and matching BINs
http://public.box.net/2500_full_kit
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
The revert to 2500 is included in the b75 directory as a subdirectory and in th eother two directories as Boot60 subdurectory.
Username: Juancho
Post Number: 2706
some receivers do this when they don't take the boot60 as they could
1 Rebootings every 10 minutes over and over.
2)some show a cero then 5 after the F for about 1 or 2 minutes without stop.
solucion install boot60 again and start over
Username: Bte
Post Number: 32
nalin should i revert back to 2500 or is there something else i can do to fix the F that appears when ever i turn on my reciever thx.
Username: Bte
Post Number: 33
ok thx i will do as u say Juan Ramirezone
Username: Nydas
Post Number: 9425
The 2500/FLU are very tolerant. You can revert and start all over - I find it the best.
ALWAYS WAIT, W A I T
W A I T - W A I T
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Need serious help with puff plz!!!! [ « Previous ] [ Next » ]
