Thread: Question Regarding Nfusion |
Silver Member Username: Nestea
Post Number: 114 Registered: Jul-06
| Posted on Sunday, March 23, 2008 - 04:23 pm: |
I understand this receiver works through broadband internet connection. My question is, if nfusion works just by connecting it to internet and then to tv, Does that mean it will work anywhere in the world, through broadband connection. I don't have one, so i don't understand nfusion very good. I will be travelling to Africa in few months. I need to know if it will work there or not. |
Silver Member Username: Rescate
VENEZUELA, M...
Post Number: 302 Registered: Nov-07
| Posted on Sunday, March 23, 2008 - 04:43 pm: |
Yes and No. nfusion doesn't need internet for FTA satellites. nfusion can receive any satellite it's depends on antenna size, location and LNB's like any other satellite receiver. The only difference about internet is flashing your receiver to watch dik and b3v signals and then doing IKS to have the keys. That's depends also on satellite reach, I don't think you will be able to receive any of them. You should check w w w . l y n g s a t.com to see what signals are available to your location and what equipment you would need to be able to capt them. Regards |
