Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Frequency step
Author Thread: Frequency step
Username: Agent_70
Post Number: 18
Never happened to me. After downloading new bin to ultra 2000, i usualy do a blind scan (vertical). I just noiced about frequency step 5-15. Which number should i choose? I have dish pro lnb
Username: Agent_70
Post Number: 19
From each sat 7 and 8 i am getting total 200 chan.
Username: Agent_70
Post Number: 20
i scan 8 with port 1 and then 7 with port 2 before but today ???????????????
Username: Plymouth
Quebec city, Quebec
Post Number: 1157
Where come from youre bin
Username: Agent_70
Post Number: 21
from dsstester
Username: Plymouth
Quebec city, Quebec
Post Number: 1158
If youre signal is hight you take higher, if poor lower
Username: Agent_70
Post Number: 22
i even used the working old one 050308 but didt work
Username: Plymouth
Quebec city, Quebec
Post Number: 1161
On which sat?
Username: Plymouth
Quebec city, Quebec
Post Number: 1163
Take 08 03 11 this the good one
Is this a clone
Username: Agent_70
Post Number: 23
on both sats when i scan everything looks good
Username: Agent_70
Post Number: 24
i downloaded that one you offer
Username: Plymouth
Quebec city, Quebec
Post Number: 1164
This the same the difference is no freeze on remote
Username: Agent_70
Post Number: 25
I have dish pro and 2000ultra
1. echo7
2. ON
3. OCS
4. 11250
5. OFF
6. 12224
7.port1
80off
none
Username: Plymouth
Quebec city, Quebec
Post Number: 1165
The LNB Freq need to be 11250, if not you dont take all channels
Username: Plymouth
Quebec city, Quebec
Post Number: 1166
How is your quality on sat 8 channel 163?
Username: The_coders
Post Number: 739
1. echo7
2. ON
3. OCS
4. 11250
5. OFF
6. 12224<--wrong , shud be 12239
7.port1
80off
none
Username: Agent_70
Post Number: 28
I will check, i need to scan again. CODERS i can watch all my 200 channels whith this situation now, but i had 600 before
Username: Plymouth
Quebec city, Quebec
Post Number: 1168
Coders
On line 6 TP Freq,that make nothing on a blind scan
Username: Agent_70
Post Number: 29
now on 8 i got 101 chans?
Username: Plymouth
Quebec city, Quebec
Post Number: 1169
ON 110W it supposed to be 351 channel thats what i take
Username: Agent_70
Post Number: 30
i had the same before
Post Number: 741
don't use 'blindscan' with viewsats they dont like it - autoscan echo 7 at tp freq 12239 then scan 110 at 12224 , factory default 1st b4 appling these new settings and then autoscan
Username: Plymouth
Quebec city, Quebec
Post Number: 1170
How is your quality on sat 110W channel 163?
Username: Plymouth
Quebec city, Quebec
Post Number: 1172
Viewsat like Blind scan what you said coders
Username: Plymouth
Quebec city, Quebec
Post Number: 1173
Dont do factory default because you will lose all setup
Username: Agent_70
Post Number: 31
i am checking now something, i will let you know
Username: Plymouth
Quebec city, Quebec
Post Number: 1174
Did you have some freeze and need to do hard reboot frequently?
Username: Agent_70
Post Number: 32
THANK YOU ALL FOR YOUR support. I found out something good about V-2000 ultra. I will be prepearing a new thread for newbies. It took me 8 hours with the help of you at the end to realize the stupid channel fix.
Thank\'s
Username: Agent_70
Post Number: 33
my next progect is nfusion. that fuuucker is sitting in my office and waiting to hear my yellings
Username: Plymouth
Quebec city, Quebec
Post Number: 1178
Good news
If you need help again, ask it.
Username: Tgyoung1
Illinois
U.s.a.
Post Number: 22
how do you get speed channel..missing transponders when blind scan?
Username: Tgyoung1
Illinois
U.s.a.
Post Number: 23
7lku
lnb standard
lnb freq.11250
22khz off
diseeqc #3
8.10
lnb standard
lnb freq.11250
22khz on
diseqc #1
Username: Nydas
Post Number: 9431
Echo 7 - First TP 12224 V (used to be 12239V)
Echo 8.10 - First TP 12224V
Username: Tgyoung1
Illinois
U.s.a.
Post Number: 24
no help thanks
Username: Plymouth
Quebec city, Quebec
Post Number: 1193
Terry it's impossible to lost transponder with blind scan. Did you delete something?
Username: Tapeman
New York City in-HD, NY
Post Number: 2633
Freq step 5 to 15 in general 10 is typical
Freq step was always there yo just never noticed it
DN has many tricks to disable VS blind scan going back to nearly a year ago like the coder said above avoid using blind scan on VS receivers
Username: Plymouth
Quebec city, Quebec
Post Number: 1197
KING blind scan work very fine now on my box, i notice again bad bin is give by different place like thetotal .
Give info for last year i dont know (disable)
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Frequency step [ « Previous ] [ Next » ]
