Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Why cant i get Bev?
Author Thread: Why cant i get Bev?
Username: Swirvin
Post Number: 89
sonciview 8000 with the latest file, the new keys, hard boot, soft boot, you name it, left it on the same channel for an hour, i cant get BEV?
ive had it before but for the last few weeks, (since the latest file) i cant get it.
any help?
Username: Fattay
Post Number: 45
You should give more details,switches,dishes,,If you had it before,, and your dish hasn't moved,,you have lasted file,then it can be only one thing,,you attenna set-up,,or port settings and or switch/switches.
Username: Swirvin
Post Number: 90
i get sound, just no pic. ive had it on older bins but the last two updates, i cant get a picture, just sound.
Username: Nydas
Post Number: 9410
Check the video connection to the TV.
Username: Swirvin
Post Number: 91
^^^^^ i get Charlie no problems, dont even need a re-boot for that. its BEV that i cant get.
Username: Fattay
Post Number: 46
Signal/Quality levels on Bev? If Ok, then it has to be port/antenna settings. Its hard to figure out with out posting your settings.
Username: Plymouth
Quebec city, Quebec
Post Number: 1141
Maybe check the keys for Bev
Keep autoroll on
Username: Swirvin
Post Number: 92
sig 71 quality 75
ive had Bev working for over six months, its just the last two updates that i cant get working.
i get Charlie perfect, never ever have a problem. ive been on the same channel now for an hour.
Username: Plymouth
Quebec city, Quebec
Post Number: 1144
Try to compared keys on Bev
Username: Fattay
Post Number: 47
Picture on dtv,not bev,but you have sound. All settings the same, but diff bins, acts like keys,,maybe one key is not working/or wrong. You might reset defalt keys,and let them roll in again.Hope this helps?
Username: Plymouth
Quebec city, Quebec
Post Number: 1151
Yegerson is right post sat setup on Bev maybe youre signal and quality come from Dish sat
(bad port selected)
Username: Tgyoung1
Illinois
U.s.a.
Post Number: 21
what difference between bev and dn .I know what dn is.?
Username: Bte
Post Number: 26
guys, i was converting my 2500 to 2700 clone to puff . puff flashes twices and stays on f for 10 seconds and restarts. plz helpp!!
Username: Nydas
Post Number: 9427
For fast recovery from a mess, read this thread and download the files.
http://www.ftatalk.com/showthread.php?t=150839
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Why cant i get Bev? [ « Previous ] [ Next » ]
