Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > PANSAT 3500 SD-Snow Picture
Author Thread: PANSAT 3500 SD-Snow Picture
Username: David_2
Post Number: 21
Need help
I have a Pansat 3500 SD and am getting a snow picture. When i turn on the main power from the back, unit indicates b-80 and the numbers come on fine.
I did JTAG with no luck
In addition, i have tried using the buttons on the unit with no luck. The capacitors on the unit are not bulged and look fine.
Can ANYONE Help.
Username: Metallica
Post Number: 404
SAMDO..did you connect all the cables back in your 3500 SD yet??
sound like you forgot to connect back some cables in the back of your box that why you see snow picture..
your box are working fine when you see the B-80 in the front and why you J-TAG it for it not dead??
Username: David_2
Post Number: 22
Metallica
Are plugs are connected in the back of the unit..........
Username: Flu_guy
Post Number: 75
There are likely 3 distinct types of output coming from the back of your box:
The RCA jacks L,R and Video, (yellow)
or
Channel 3/4 probably labeled TV OUT, (check 3/4 switch position matches TV channel)
or
S-VIDEO, small round connector with 4 holes.
Which one are you using?
Htiek
Username: David_2
Post Number: 23
Htiek
I am using 3/4 and it is the correct setting on the unit as well as the TV.
I am NOT using the S-Video or the RJW Jacks
Username: Dimwitt
Post Number: 511
Try a different video output and see if problem remains. --maybe a bad cable from 3500 to TV.
Username: Plymouth
Quebec city, Quebec
Post Number: 1179
Guy i think this is the video processor, bad cable or input select give a black screen without snow.
Htiek try to unplug your box for 1 hour,
for cooling the chips and reset data in this one.
Good luck
Username: Flu_guy
Post Number: 76
Hi everyone
Could be the tuner too, especially if it works OK when the RCA jack outputs are used...
Htiek
Username: David_2
Post Number: 24
All
I should let you know the cables are all fine....You see I have a Pansat Unit and I plug it the same way......I am trying to help a friend of their unit......All Cables , DIseq Switches are ALL Fine........I think it maybe a problem in the tuner (this is what i need the technical expertise on).
Does anyone have any other suggestions?
Username: Flu_guy
Post Number: 77
Hi Samdo
Did you try the RCA outputs yet? they don't use the tuner, so they might still be OK...
By the way, I take it that everything, menus and all, is snowy, not just the TV program?
Htiek
Username: Nydas
Post Number: 9417
Try The two audio outs and use s-video for the video. Do not connect the video out of the RCA.
Use the Video 0 of the TV set.
HAPPY VIEWING.
Username: Nydas
Post Number: 9418
By audio outs, I meant the left ant right audio out of one set.
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > PANSAT 3500 SD-Snow Picture [ « Previous ] [ Next » ]
