Thread: Viewsat ultra |
New member Username: Brucris
Post Number: 1 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 09:21 am: |
my vs ultra is giving message that is searching for signal what shoul I do? |
Gold Member Username: Nydas
Post Number: 9399 Registered: Jun-06
| Posted on Saturday, March 22, 2008 - 09:26 am: |
Make sure autoroll is on and autotp off. Switch off at back - wait 30 seconds, switch on. Wait for 5-15 minutes for autoroll to work. |
Post Number: 2 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 09:29 am: |
I will try that, thanks I et you know |
Post Number: 3 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 09:34 am: |
I did what you said Nalin, autoroll is on, but still searching signal |
Post Number: 4 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 09:41 am: |
Anybody has a new idea? |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 1120 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 09:54 am: |
I may help you How is the signal and Quality |
Post Number: 5 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 09:58 am: |
It is around 32, I am in Puerto Rico, the signal here is not the best |
Quebec city,
Quebec
Post Number: 1121 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:02 am: |
OK it's enough try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote no need to delete keys switch off 10 secs on back panel and load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll, freeze and search signal Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV TESTED and work fine New issue for problem on Viewsat Thanks Do a blind scan on your sat after for recover all channel Because some new freq are provide Dont do a factory reset and factory bin No need it Reply if it work Please |
Post Number: 6 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 10:15 am: |
Thanks, I will try that and let you know |
Post Number: 7 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 10:26 am: |
It did not work, dish is my provider and I delete it, how I put it back? |
Bronze Member Username: Tekomi_elhoyo
Post Number: 70 Registered: Jun-06
| Posted on Saturday, March 22, 2008 - 10:50 am: |
Enter the keys manually and turn autoroll off. The keys are the following DISH 00 (86): 84 7A 93 DF 2C A9 16 55 58 18 CD 18 22 FE 4B DE --> Date: 03/22/2008 10:28 AM DISH 01 (96): CB 34 81 CF A3 CA 5C B2 42 E0 1B 07 33 A3 6C 64 --> Date: 03/21/2008 10:58 PM I would recommend resetting your box with factory program and then installing latest bin. Then, doing a channel scan. |
Post Number: 8 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 10:53 am: |
thanks I will try that |
Silver Member Username: Madflea168
Post Number: 369 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:54 am: |
if you delete the key like plymouth posted, you will need to reload the latest bin like he posted as well. sometimes vs would lose signal, after hard reboot, switch off/on from the back should able to reset it. if not, go to antenna settings, make sure everything there is still correct. signal meter is more likely to be voltage feeding the lnbs, quality meter is more important, if there is no quality at all, there will no tvs. you can always do a fac reset=load fac bin/latest bin, if still not work, the last option is fac default which wipes everything to original state=load fac bin/set fac default/load latest bin/ Always switch off from the back after new bin load completed, and wait a few minutes before reboot, this helps the new bin and auto roll to kick in. good luck. |
Quebec city,
Quebec
Post Number: 1122 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:55 am: |
NO put last bin like is write that restore provider and keys |
Quebec city,
Quebec
Post Number: 1123 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:58 am: |
That restore 01 06 00 and 00 01 00 and 01 01 00 is rgenerated by autoroll |
Quebec city,
Quebec
Post Number: 1124 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 11:00 am: |
Tekomi please I know what i do stay away |
Gold Member Username: Cartier1
Post Number: 1774 Registered: Feb-07
| Posted on Saturday, March 22, 2008 - 09:48 pm: |
PLYMOUTH after deleting the porivider and after flashing with the latest 08-03-11u i can not see 01 06 provider only got 0101 and 0001 i lost all the pictures. work fine with bev but not dn |
Quebec city,
Quebec
Post Number: 1139 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:06 pm: |
Cartier load bin 08-03-05 before 08-03-11 Do a hard reboot between each bin |
Quebec city,
Quebec
Post Number: 1142 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:15 pm: |
Cartier Which VS Model |
Post Number: 1775 Registered: Feb-07
i just downloaded 08-03-05 i checked still no 06 01 00 provider |
Post Number: 1776 Registered: Feb-07
| Posted on Saturday, March 22, 2008 - 10:17 pm: |
viewsat ultra |
Quebec city,
Quebec
Post Number: 1143 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:20 pm: |
Said me where you take your bin? |
Post Number: 1778 Registered: Feb-07
| Posted on Saturday, March 22, 2008 - 10:23 pm: |
from thetotal it was working great some autoroll a nd little freez made me do what you suggested deleting the 3 provider. and that's where i screwed up . |
Quebec city,
Quebec
Post Number: 1146 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:27 pm: |
Cartier try the bin to dsstesterDOTcom select in left side Viewsat files and download the bin 08-03-11 |
Post Number: 1779 Registered: Feb-07
| Posted on Saturday, March 22, 2008 - 10:43 pm: |
PLYMOUTH i owe you one , just did and everything is back. no more dowbloading from thetotal. thanx |
Quebec city,
Quebec
Post Number: 1150 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 10:44 pm: |
Good i'm very happy for you |
