Thread: Something happened to my viewsat (noCH) |
Silver Member Username: Ariza
Post Number: 236 Registered: Feb-06
| Posted on Friday, March 21, 2008 - 09:27 pm: |
This is strange.. i was watching TV and all of a suddenly everything blacks out and the receiver says "noCH" Even if i load the factory bin and the new file (march 11) it still says the same thing when i turn it on... |
Silver Member Username: Madflea168
Post Number: 360 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 09:44 pm: |
you may just lose everything, need to re-scan. or delete dn's key in the code menu like plymouth posted. c/p try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote no need to delete keys switch off 10 secs on back panel and load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll and search signal Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV TESTED and work fine New issue for problem on Viewsat Thanks Do a blind scan on your sat after for recover all channel Because some new freq are provide Dont do a factory reset and factory bin No need it |
Post Number: 237 Registered: Feb-06
| Posted on Friday, March 21, 2008 - 09:46 pm: |
na man i can't even control my remote control when i turn on the receiver... nothing works! |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 1091 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 10:13 pm: |
Try a hard reboot (switch off 10 secs on back panel) if remote not work reply |
Post Number: 238 Registered: Feb-06
| Posted on Friday, March 21, 2008 - 10:23 pm: |
^ nope, still doesn't work.. you know where i could get the factory default file? |
Quebec city,
Quebec
Post Number: 1095 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 10:31 pm: |
Yes Which VS you have |
Post Number: 239 Registered: Feb-06
| Posted on Friday, March 21, 2008 - 10:36 pm: |
Viewsat platinum... btw im going to (1)load factory default file, (2) load latest factory file, (3) load latest bin and see what happens. |
Quebec city,
Quebec
Post Number: 1096 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 10:54 pm: |
OK Jib go to viewsatusa.com/support and download, unzip and install: Loader 1 - Firmware Updater (Plat and Xtreme) and download : VS2000 Platinum & Lite Factory Bin File - V0278 unzip it and load in receiver do a hard reboot load last bin for your box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote no need to delete keys switch off 10 secs on back panel and load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll and search signal Do a blind scan on your sat after for recover all channel Because some new freq are provide Now it supposed to work Good luck |
Post Number: 240 Registered: Feb-06
| Posted on Friday, March 21, 2008 - 11:17 pm: |
I'm an experienced FTA user, i know how to set up the receiver once its fixed. However, even when i do a hard reboot and load the latest factory file, it still gives me the same error message "noCH" and nothing works at all.. not the remote control nor the features on the receiver, such as CH or Volume.. it's frozen on a blue screen.. |
Quebec city,
Quebec
Post Number: 1098 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:32 pm: |
Jib you load factory from viewsat or not? If yes try unplug your box for 1 hour, that may reset function like remote and you supposed lost pass word if you have. |
Post Number: 362 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:36 pm: |
if you did the fac reset and still no go, I guess you will have to do load the fac bin and default the box then load the latest bin is the last option. good luck. |
Post Number: 241 Registered: Feb-06
I loaded the factory file, then the latest fix, still no luck.. i'll load the latest fix again, and reboot after an hour |
Post Number: 363 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:38 pm: |
default it? |
Quebec city,
Quebec
Post Number: 1099 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:40 pm: |
Mad read remote dont work and button on receiver too |
Post Number: 365 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:44 pm: |
does remote work after the fac bin loaded and before the latest bin? |
Post Number: 242 Registered: Feb-06
| Posted on Friday, March 21, 2008 - 11:47 pm: |
Okay never mind. I took it back upstairs and pressed the "menu" button. It's working. After i do a blind scan, it should work. If it still doesn't work, i'll be sure to let you guys know. Highly appreciate everyone's input and time. Cheers! |
Quebec city,
Quebec
Post Number: 1100 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:48 pm: |
Maybe you may try it to force factory bin: When you laod factory bin before it is end switch off rear switch aand retry to load it |
Quebec city,
Quebec
Post Number: 1101 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:49 pm: |
Good news Jib If you need help just ask |
Post Number: 244 Registered: Feb-06
| Posted on Saturday, March 22, 2008 - 12:13 am: |
thanks to plymouth and madflea, everythings cool.. back up as usual have a good one guys! |
