Thread: Question about converted |
Silver Member Username: Batjc
Post Number: 118 Registered: Aug-07
| Posted on Friday, March 21, 2008 - 08:31 pm: |
where can i find a guide that can show me... how to convert to puff... thx |
Silver Member Username: Madflea168
Post Number: 361 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 11:01 pm: |
did you do a search? it seems there are a lot pop up with google and in this forum. good luck. |
Silver Member Username: Metallica
Post Number: 393 Registered: Jan-08
| Posted on Saturday, March 22, 2008 - 12:45 am: |
Jeancarlos check that link out there are a lot of infor there about how to convert to puff.. http://forum.ecoustics.com/bbs/messages/2/461944.html |
Gold Member Username: Nydas
Post Number: 9398 Registered: Jun-06
| Posted on Saturday, March 22, 2008 - 09:23 am: |
For Pansat 2500/FLU new conversions and converted to 2700 Use only on unconverted 2500/FLU or converted receivers. DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 boot or PUFF boot or PUFF_LZMA boot and matching BINs http://public.box.net/2500_full_kit Read the instructions properly in the section you have chosen. PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS. |
Silver Member Username: Jkmago
Post Number: 183 Registered: Nov-07
| Posted on Saturday, March 22, 2008 - 09:29 am: |
What is the difference between PUFF boot or PUFF_LZMA boot? Nalin, can you explain in detail Thanks |
Post Number: 9401 Registered: Jun-06
| Posted on Saturday, March 22, 2008 - 09:54 am: |
Jogi Mago: Download Conversion_Main.doc from http://public.box.net/2500_full_kit For anybody reading this thread -- Instead of asking questions, download and read. There are EXTENSIVE instructions in all three sections. |
Bronze Member Username: Omar_nab
Post Number: 44 Registered: Oct-07
| Posted on Sunday, March 23, 2008 - 04:05 pm: |
hi nalin i have 2500 converted to b75 fter is converted to puff which bin work now thanks |
Post Number: 419 Registered: Jan-08
| Posted on Sunday, March 23, 2008 - 04:36 pm: |
Omar use this Puff bin.. Jvvh_258_Nkk_PUFF http://www.ftabins.net/forumdisplay.php?f=128 |
Post Number: 9420 Registered: Jun-06
| Posted on Sunday, March 23, 2008 - 07:20 pm: |
When you turn on the receiver, if it scroll b-7-5 then use a b75 BIN. If it scrolls P-U-F-F then use a PUFF BIN. You can use the one mentioned above. There are 4-5 different ones avaialble. If you download ALL_PUFF_258.zip from teh PUFF subdirectory at http://public.box.net/2500_full_kit you will be able to choose amongst the ones available |
