Thread: Echo 8-10 settings help |
Bronze Member Username: Chip_la
Post Number: 42 Registered: Oct-07
| Posted on Friday, March 21, 2008 - 03:52 pm: |
Hi Could someone give me the sat. settings for echo 8-10.freq.line power.ports,etc.I can't seem to get them right. I used get some channels but not any longer. Thanks chip |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 1083 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 05:40 pm: |
Explained it: I used get some channels but not any longer. |
Silver Member Username: Madflea168
Post Number: 357 Registered: Jan-08
| Posted on Friday, March 21, 2008 - 07:17 pm: |
for 110/119 the settings are the same except the port on the switch. 119 on port #1, 110 on port #2. both uses freq 11250, lnb type base on the lnb you use, if from dn use osc-dp. you probably get better signals/quality on 119 from 12239 rather than 12224. good luck. |
