Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > ViewSat Xtreme VS2000 Question??
Author Thread: ViewSat Xtreme VS2000 Question??
Username: Sunshine123
Post Number: 7
Have a View Sat Plat and works fine Friend ask if i can get his View Sat Extreme working , so i go go and put in a bin and no luck?
What did i do wrong?
Did get channel guide with no info ...
Thanks to all that can help
Username: Dann1
probebly have non working bin
Post Number: 8
Thanks Dano
Would you or anyone else know of a working Bin, if that is the case?
Thanks
Username: Plymouth
Quebec city, Quebec
Post Number: 1060
Leaf your problem probably resolve with it:
try it:
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
no need to delete keys
switch off 10 secs on back panel
and load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll and search signal
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Do a blind scan on your sat after for recover all channel
Because some new freq are provide
Dont do a factory reset and factory bin
No need it
Reply if it work
Please
Username: Madflea168
Post Number: 353
try to download the latest bin again.
Username: Plymouth
Quebec city, Quebec
Post Number: 1071
Mad Flea just to read, he did it
Username: Thetaffey
Post Number: 24
Hey, Im getting only 254 channels for echo 3, is that it? or do i folllow plymoth's advice. Thanks
Username: Thetaffey
Post Number: 25
Hey, Im getting only 254 channels for echo 7, is that it? or do i folllow plymoth's advice. on vs extreme Thanks
Username: Metallica
Post Number: 362
go ahead and try Plymoth advice..you have nothing to lose..
BTW there some peoples say they picked up more channels than B4 after they follow Plymoth advice.
Username: Plymouth
Quebec city, Quebec
Post Number: 1078
The first confirm to me it work is KING Taperman.
Post Number: 9
Plymouth thanks once again for all your help
Did what you told me to do from above post, still no luck.
Maybe when I did blind scan was not on correct setting, I have it on Echo 8,10 if antenna is issue could you tell me how i should have it set up ?
Should I set the antenna up the way my viewsat platium is set up or something diffrent or I am totally wrong on everything and maybe I did something wrong??
Thanks again
Username: Plymouth
Quebec city, Quebec
Post Number: 1088
You need to do blind scan, because new freq is insert by provider.
Go to menu
installlation
and blind scan.
The sat setup is
satellite Echostar 110W
LNB Power on
LNB type Standart
LNB Freq 11250
22 Khz off
Diseqc 1.0 none
Motor none
Legacy SW none
Post Number: 358
before you do either auto or blind scan, if you don't have any signals/quality on any of the tps, you probably have to check your antenna position first.
check dishpointer.com for correct place, if antenna is in the right place, and not getting too much of the channels, maybe need to fine tune the antenna.
your xtreme and plat should ok to use the same settings.
good luck.
Username: Kirankumar
NO Bashing
Post Number: 2237
Plymouth,
you need to slow down,i think this guy is complaining about channel guide only,
cab you ask him and clarify before recommending anything else,
also the settings you posted may not work for him,he may have a different lnb type,so ask for his set up first
Username: Plymouth
Quebec city, Quebec
Post Number: 1090
Leaf give me news please and read what Mad and African says.
Username: Luser
Post Number: 141
Getting channel guide with no info. Your antenna settings are incorect or dish not aligned.
Username: Koko_wawa
Post Number: 287
If you do not have channel guide, it means your antena settings are incorrect. correct them you will get channel guide.
Username: La_tounis
Hi everybody !!
I have a Viewsat Uutra VS 2000, and I got the files for the keys on a usb key. I tried to download this program on my sat but it didn't work. I think i did what i have to do but there a step that I did wrong. These are the steps : I went on MENU, System information, Receiver upgrade, USB, and after I clik on each file and I did F4. I closed the receiver and put it on but nothing works. I got the message like Autoroll processing but nothings appears. Can someone help me on that ! I never did that before that's why
Thank you for collaboration
Username: Plymouth
Quebec city, Quebec
Post Number: 1129
You must unzip before.
If it not work. You must do that :
try it:
All viewsat box
Go to Code menu
turn autoroll on
Keep on
ENJOY TV
Thanks
No need it
Reply if it work
Please
Username: Plymouth
Quebec city, Quebec
Post Number: 1130
Imene why you do F4
You must do OK to load
Username: La_tounis
hi plymouth do you speak french ? it's gonna be more easier ?
Username: La_tounis
salut ! écoute le fichier dans ma clef est composer de 4 sous fichier qui ont pour nom des genres de numero de cléf. Comme je le disais j'ai insérer ma cléf USB et fait menu ensuite systeme d'information , USB, et lorsque je clik sur le fichier comprenant les 4 autre fichier, ensuite je clik sur chacun des 4 fichiers, un a la suite del'autre et un message apparait apres chaque clik. Le message est READ File. ensuite il ne reboot pas tout seul. et mon autoroll est a ON j'ai vérifié. Si tu pouvais m'aider ca serait coooolll :-)
Merci
Username: Plymouth
Quebec city, Quebec
Post Number: 1132
OK mais cé pas la bonne facon. Met directement la bin décompressé sur la clé et fait OK, la ca va marché.
J' ai fait un test comme tu le fait et ca fait rien aussi.
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > ViewSat Xtreme VS2000 Question?? [ « Previous ] [ Next » ]
