Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Channel problem
Author Thread: Channel problem
Username: Sluggp
Post Number: 27
I did a blind scan to get new/changed channels and I ended up with 4/5 of the same channels so I deleted all channels and did a new scan. Again I have multiple channels. I also lost my local channels 3,5,10,15,44,55.
Is there any way to delete the duplicated channels?
and how can I get my locals back?
any help would be appreciated.
Im using Viewsat Extreme.
Username: Sluggp
Post Number: 29
I also lost alot of ppv channels...
Username: Plymouth
Quebec city, Quebec
Post Number: 1053
John
try it:
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
no need to delete keys delete
switch off 10 secs on back panel
and load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Resolve problem with lost channel , autoroll and search signal
Thats erase bad data in the box
For box who lost channel and sat setup
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Do a blind scan on your sat after for recover all channel
Because some new freq are provide
Dont do a factory reset and factory bin
No need it
Reply if it work
Please
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Channel problem [ « Previous ] [ Next » ]
