Thread: 9000hd problem.. need help |
Bronze Member Username: Droy1
Huntington beach,
Ca
Orange
Post Number: 36 Registered: May-06
| Posted on Thursday, March 20, 2008 - 07:27 pm: |
when I turn on the box it boots to the b-06 like it should then instead of going to a channel it goes ---- then it goes to like InIb or 1n1b but on either one the b isnt complete. The b can look like a small t which i think it is. Can someone help me with this on what to do and what happened... Thx alot |
Gold Member Username: Plymouth
Quebec city,
Quebec
Post Number: 1046 Registered: Jan-08
| Posted on Thursday, March 20, 2008 - 07:34 pm: |
Can you put the bin with USB? |
Huntington beach,
Ca
Orange
Post Number: 37 Registered: May-06
| Posted on Thursday, March 20, 2008 - 07:43 pm: |
no I cannot because the screen doesnt even come on |
Silver Member Username: Dimwitt
Post Number: 505 Registered: Aug-06
| Posted on Thursday, March 20, 2008 - 08:02 pm: |
the language screen should be on the tv when --init-- is displayed on 9000 if no menu C/P Restore Dead Pansat 9000 units This is a very simple way to restore any 9000 Hd unit if it is stuck on b-05,06,07 Download the factory bin and rename the file to API_FILE Once you rename the Factory bin to API_FILE you can apply this to your usb memory stick alone in no folders Step:1 Rename the factory bin to API_FILE Step:2 Put the API_FILE on your USB stick in no folders Step:3 Plug the unit in with the power off Step:4 HOLD the Right button on the face plate with the USB Stick plugged in Step:5 Turn the power on with the toggle switch wile you are still holding the right arrow Step:6 API will appear on the screen you now can stop holding your right arrow Step:7 it will say API,Succ,End Step:8 If it doesnt work please re try the steps again |
Quebec city,
Quebec
Post Number: 1049 Registered: Jan-08
| Posted on Thursday, March 20, 2008 - 08:11 pm: |
Darren i dont know if a loader for your box you may try to download and install on computer this loader : VSPRO Loader - Firmware Updater ( Serial) on viewsatusa.com/support and load factory bin with it. before check in you origin packing if a cable and instruction is furnish. If you need more info reply. |
Huntington beach,
Ca
Orange
Post Number: 38 Registered: May-06
| Posted on Thursday, March 20, 2008 - 08:13 pm: |
Then i should load the updated bin.. right and thats it? When i rename the file is it when i extract it to a file? |
Quebec city,
Quebec
Post Number: 1050 Registered: Jan-08
| Posted on Thursday, March 20, 2008 - 08:14 pm: |
Oh it's a Pansat listen Tooter |
Huntington beach,
Ca
Orange
Post Number: 39 Registered: May-06
| Posted on Thursday, March 20, 2008 - 08:17 pm: |
Plymouth i got he factory bin on my desktop now i just have to put it on my usb stick and give it a try i guess. I want to thank all for help and continue to give all info.. thx darren |
Huntington beach,
Ca
Orange
Post Number: 40 Registered: May-06
| Posted on Thursday, March 20, 2008 - 08:27 pm: |
Tooter... What due you mean the language screen should be on tv... is there something im not getting here |
Post Number: 506 Registered: Aug-06
| Posted on Thursday, March 20, 2008 - 08:37 pm: |
init is displayed when all your saved settings are lost --like after a factory default. you should have a menu screen ( select language ) on the tv , so you can set up the receiver and scan the sats your aimed at. |
Huntington beach,
Ca
Orange
Post Number: 41 Registered: May-06
| Posted on Thursday, March 20, 2008 - 09:48 pm: |
tooter i have no menu screen on the tv and the api file didnt work.. anything else we can try or due |
