Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > 2 satellites and one receiver
Author Thread: 2 satellites and one receiver
Username: Moly
Hi Everyone.
I have to satellites and cannot get channels from both on my CW800 PVR. I am using a Diseq (i think i got the spelling right) where i can get all three lnb hooked into the cable box entering the house. however, i can get channels from one dish or the other.. and channels of the other tell me that the signal is weak... do you have any advice on this issue?
Thanks a lot
Username: Kirankumar
NO Bashing
Post Number: 2212
your antenna settings may be wrong,
go to menu>satellite and you will see settings there
post settings for all three sats so we can help
you will see things like
lnb type
frequency
switch
etc etc
Username: Moly
Post Number: 7
Will do as soon as i get home... thanks a lot
Username: Moly
Post Number: 8
Hi Again...
after writing the settings, i found that i had diseq set as none... i set it to auto and it worked...
so here is another question: dishes 119W and 110W, do they have the same channels? cause they sure looked like they did when i scanned the channels of both...
is there any reason that i should have both connected?
Username: Moly
Post Number: 9
also... should i have the diseq setting as auto or put the actual lnb number? would it make the transition from one echo 3 to echo 7 faster, and vice versa?
Username: Moly
Post Number: 10
ok guys.. me again...
transition from the channels of one satellite to the other takes over a minute... is there a way of have the transition somoother?
Second Satellite: Echostar 7 (119 W)
echo star 7- (119w)
transponder: 12224/v/20000/5/6
lnb freq: 11250
lnb tybe: normal
22khz: auto
diseq no : auto
legacy sw : 0ff
motorised system : none
Second Satellite: Echostar 3 (61.5 W)
echo star 7- (119w)
transponder: 12224/v/21000/500/2/3
lnb freq: 11250
lnb tybe: normal
22khz: auto
diseq no : none
legacy sw : 0ff
NO Bashing
Post Number: 2230
Moly,
adjust 22khz to off on both and diseq
for 119 adjust to 119 and for 110 2
and for 61.5 set switch to 3
and scan again.
post results
Username: Madflea168
Post Number: 351
119 on port 1, 110 on 2 and 61 on 3.
Username: Moly
Post Number: 12
thanks guys for the response... what i did was put 119 on 1 and 61.2 on 2.. and transition is just beautiful.... i dont have the 110 connected.. when i connected a while ago it downloaded very smilar channels to 119... is there a difference between the channels of 119 and 110? is it worth going through the trouble
Post Number: 355
110 and 119 have different channels, check lyngsat for more channels line up.
make your you do lock on the sat, so you know it is the right sat you want.
good luck.
Username: Moly
Post Number: 13
thanks for the answer made flea...
what is lyngsat? and what do you mean by lock on sat?
NO Bashing
Post Number: 2236
go to wwwdotlyngsatdotcom
Post Number: 359
I would believe cs has the same feature like the vs, with the locked sat showed in the set up menu screen.
lyngsat dot com is a site you can get infos on tps freq and channels line up.
you may want to have 110/119 on one dish and 61 on the other by itself.
check dishpointer.com for correct position and fine tune with sat finder or bring tv/box to the antenna for easier tunning.
good luck.
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > 2 satellites and one receiver [ « Previous ] [ Next » ]
