Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Laptop connection with tv.........
Author Thread: Laptop connection with tv.........
Username: Saqeeb9000
Post Number: 2898
hi all i have wireless laptop and high defination tv.. my laptop is not built with tv tuner. so in order to watch computer stuff (you tube etc ) on tv what do i need? is HDMI cable going to work or do i need to get tv tuner
Username: Kayoss
Post Number: 22
I think you are going to have to hook some kind of a wire up to that wireless laptop and then by high definition it will no longer be wireless!
Username: Plymouth
Quebec city, Quebec
Post Number: 1023
Sada check on your tv it supposed to have a VGA input, on your laptop too.
Just buy a cable with appropriate lenght.
Post Number: 2899
are u talking about this
Username: Plymouth
Quebec city, Quebec
Post Number: 1024
Some laptop have a S-Video out
better then nothing and cheaper
Username: Plymouth
Quebec city, Quebec
Post Number: 1025
Exact, this one
Post Number: 2900
it also built in svideo .. cable.
thanks
Username: India101
Post Number: 35
i have question on that if i have VGA Out put on my laptop and S-video on my TV will the resolution will be better or S-video to S-video will be better. I don't have VGA out put on my TV
Username: Plymouth
Quebec city, Quebec
Post Number: 1038
Krish SuprVga is high definiton
and S- video is the best NTSC you can have.
On your Laptop, maybe you nee to use N Vidia for transfert on S-Video output.
On mine that work with it.
It's more easy to found a S-Video cable and cheaper.
Username: Deptrai_cachon
Post Number: 91
sada , you don't need tuner to get signal from your computer to tv .
you just need to find out if your computer support output, most of the time it like a serial port from computer to tv.
tv tuner is need if you want to watch tv channels on your laptop
Username: Plymouth
Quebec city, Quebec
Post Number: 1039
Ken this is not a serial, this is a video out.
Username: India101
Post Number: 36
my main question is that if i go from VGA TO S-video the quality will be better or
if i need to buy a laptop that is s-video
Username: Boboshan
Somewhere, Out There
Post Number: 103
Very few tv's have a VGA input as it is more common for a computer monitor than a tv - but it is not unheard of. If your laptop has an s-video output, then all you need is an s-video cable to connect as most tv's today have an s-video input.
FYI, VGA has a 480x640 resolution in just 16 colours (4 bit colour). In it's NTSC variant, S-video is the equivalent of 480x720 in 32 bit colour.
Hope that helps!
Username: Plymouth
Quebec city, Quebec
Post Number: 1040
Krish Vga to S-Video is impossible if you dont have this output on computer and program for it.
Mr bobo it's superVGA not VGA
SuperVGA 480x720 32 bit like S-Video but better quality.
But it may be different accordind video card
Username: Kirankumar
NO Bashing
Post Number: 2216
Sada,
best solution is hook up S video cable and you are set
Post Number: 2905
ok thank you all...
Post Number: 2907
ok guys i got the cable .. now for some reason.. i am not getting any thing on tv screen with this.,., do i need to change setting ..
Post Number: 2908
i bought this cable
Username: Plymouth
Quebec city, Quebec
Post Number: 1064
OK Sada like i says on top you need to configure in N Vidia in setup panel
which laptop you have
First try on dvd if it work on tv
Post Number: 2909
ok got it .. thanks plymouth u are best.. is there any way to hear a sound on my tv too or do i need to hear it from computer..
Username: Plymouth
Quebec city, Quebec
Post Number: 1065
Take a cable with earphone jack to RCA
buy it in WalMart it is cheaper and easier to found
Post Number: 2910
any pics so that i know what to look for?
Username: Plymouth
Quebec city, Quebec
Post Number: 1067
Wait a minute i come back with it
Username: Plymouth
Quebec city, Quebec
Post Number: 1069
Sada the first picture is 1/8 jack like earphone to connect in laptop
the second picture is RCA connect in TV. Note the color not yellow and white but red and white
Yu need too a extension 1/8 jack male and female you can buy it in WalMart
The third picture is what i drink tonight
Post Number: 2912
ok thanks.. what i have is samecable yellow,white and red ... i think its different............
so you mean one end is in black colour and the other end is in red and white.. right.
Username: Plymouth
Quebec city, Quebec
Post Number: 1077
Right Sada , for picture, i use 2 different cables, that why you see yellow.
How is youre picture?
Post Number: 2913
picture is ok.. just can't select option on my tv for comp..setting.. i cannot highlight it for some reason.. i think on my tv there is option to change screen size etc.
Username: Plymouth
Quebec city, Quebec
Post Number: 1079
Check in laptop setup panel maybe it's there
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Laptop connection with tv......... [ « Previous ] [ Next » ]
