Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Conversion BIN 257 - PUFF only
Author Thread: Conversion BIN 257 - PUFF only
Username: Nydas
Post Number: 9334
Please NOTE that this is NOT LZMA
PUFF_257 - NOT LZMA
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included. Either b75 or PUFF
http://public.box.net/2500_full_kit
You must select whether you want to have the old b75 files or the new PUFF files.
If you have b75 boot, you must convert to PUFF boot to use PUFF BINs.
Read the instructions properly in the section you have chosen.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Juancho
De los cerros mas alto..., BINDURABLE.
Post Number: 2629
RE- 257 Puff bins posted by nalyn
The remote did not work on clones.
However the remote will work on your original pansat2500a box
Username: Nydas
Post Number: 9352
I have posted a URL above where they have used my instructions for the installation of the conversion with my permission to use.
Anything else belongs to the site owner.
The same files that are posted there are also posted at
http://www.ftatalk.com
NONE OF THE FILES ARE MY WORK
If they work well, it is because of the work of the authors of the file. If there are bugs in the files that you are concerned about, please contact the file modifiers.
Username: Hades305
Post Number: 29
puff 257 worked well with my clone
Username: Hicham
Post Number: 120
Jvvh_Fortec-Pansat_257_PUFF_(Lzma).zip
http://www.ftabins.net/showthread.php?t=32206
Username: Postergirl1
Post Number: 74
Puff
Username: Ladybug222
Post Number: 7
New term for me - what is Puff? Is that the author of file?
I have converted 2500A to 2700 - this file okay? I know - I know - I am reading and looking - lol
Post Number: 8
Okay - guess I found answer. Been away is reason I am behind the times here. I guess I have to convert to Puff now....
Should be fun....
Thanks for everyone to keep this going. Sure worth a try on my part.
Appreciate all the help....
Home > Message Board > Home Video > Satellite TV > Archive through March 23, 2008 > Conversion BIN 257 - PUFF only [ « Previous ] [ Next » ]
