Home > Message Board > Home Video > Projectors > Samsung HL-R3667W Projection Lamp
Author Thread: Samsung HL-R3667W Projection Lamp
Username: Marmorris
I have a Samsung HL-4667W TV less than three yrs. old. The projection lamp that came with the tv, a BP-0096823A, has been discontinued and I was told to order a BP-9601403A as the replacement. Received the lamp and it slides into place perfectly; however, it does not come through the back of the casing; therefore, preventing me from screwing the lamp casing in. I am frustrated because I have made 8 calls this morning and I can't seem to get an answer to solve the problem. I do not feel I should have to pay for a service call if this issue is not something caused by me.
Has anyone else experienced this or does anyone have any suggestions as to how I this can be fixed?
Thanks,
Peggy
Username: Ovadoggvo
Post Number: 225
Peggy,
Try this website:
http://guides.fixyourdlp.com/guides.php
They have videos and guides to help you through the installation process of the lamp.
Username: Ovadoggvo
Post Number: 226
and Peggy.. Worst case senario, you can take the bare bulb out of the new case and put it into your old casing that fit originally into your TV without any problems.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > Projectors > Samsung HL-R3667W Projection Lamp [ « Previous ] [ Next » ]
