Home > Message Board > Home Video > Satellite TV > Archive through June 21, 2008 > NEW KEYS (Part-2 continuation thread) > Archive through February 27, 2008
Author Thread: Archive through February 27, 2008
Username: Adrenalyzer
Post Number: 10
when sat scan, i don't get all the chans, its 4 conv... 2500a, using bin jwh252, no cnn, ect...wats up
Relevant Product Info
Post Number: 11
and also, no matter wat sat i scan (110)-(119) i get the same chans from each scan, hhmmmm!
Post Number: 12
A little help plzzzzzzzzzzzzUpload
Username: Parathesi
Post Number: 24
bin 152 for pansat2500A is out at ftabins.net
Username: Mshah2006
Mississauga, Ontario
Post Number: 42
ed mc,
Like your global warming presentation. Are you showing what is there for 2007 and 2008. May be invisible....
Username: Mshah2006
Post Number: 43
DJ.. You need a cable with 9 pin female connectors on both sides. If it did not come with your receiver, go back to a satellite store and ask for it. It should not be more than $6.00. You use it between one of the com port on the computer and your satellite 9 pin connector.
Username: Metallica
Post Number: 161
maybe 2010 you only see is a pair of lips and some hair..
Username: Halo
Toronto, Ontario
Post Number: 388
new releases at www.dish-keys.blogspot.co* (replace * with m)
Post Number: 13
UploadHey check out the new bin isle, opp's
Post Number: 15
hey, we pulled another bin
Username: Mshah2006
Post Number: 44
Is Bin 152 Working for DN?
Username: Mshah2006
Post Number: 45
I mean Bin 252.
Username: Nydas
Post Number: 8410
BIN 252 is working for DN and BEV
Username: Parathesi
Post Number: 25
Bin252 is 100% working for DN and BEV.
BL252T lightning is the right bin for pansat 2500a coverted to 2700. I downloaded it from www.ftabins.net .I test it good. It works.Pansat won this time too in cat and mouse game.
Username: Jjnelly
Post Number: 7
what are the new keys for dn
Username: Mshah2006
Post Number: 47
Thank you Nalin and SS.
Username: Ather_da_don
Mississauaga, Ontario
Post Number: 398
All the new bins are also out at www.dishkeyz.blogspot .com (remove the space)
Username: Ariana_70
Sorel-Tracy, Quebec
Post Number: 120
has anyone lost their ppv ??? i just woke up and no ppv :-(
Username: Abusubhan
Post Number: 23
Can some please help me understand this. How would i find out what Bin # I have on my ViewSat Ext and Plat.
How can I get this Bin 252. Mostly the Bins I download from FTAHQ have release date tagged with them.
I would appricate an answer and thanks in advance.
Abu
Username: Nydas
Post Number: 8423
YOU ARE CONFUSED.
BIN 252 has nothing to do with Viewsats - It is a Pansat BIN.
The latest Viewsat BINs are dated yesterday and you can download from
http://www.ftahq.com
http://www.ftatalk.com
If you have not updated your BIN in the last 2 days - you don't have the right BIN.
Username: Abusubhan
Post Number: 24
Thank you Nalin. You are the best.
Abu
Post Number: 400
Bin 252 is out at www.dishkeyz.tk!
Username: Swredneck
Halifax, N.s.
Post Number: 45
i can t seem to pick up bell i don t think its down just a very weak signal anybody else havin this prob d.n. is workin fine!
Username: Swredneck
Halifax, N.s.
Post Number: 46
nalin are u around my dish net is workin fine but my bev on pretty ni every channel no signal we hada big snow storm here last night when it went out but today is fine enough still no signal on bev everything looks fine out doors equip. i mean any i deas would be apreciated i got a s.v. 1000 and i never went into settings oranything!
Username: Nydas
Post Number: 8430
You will have to rescan, make sure your settings including switch settings are OK.
Username: Fganatra
Torrance, Ca
Usa
to Nalin i ma looking new bin for cs 5k pl help thank you
Username: Nydas
Post Number: 8433
NO for C00LSAT 4000, 5000, 6000. Maybe Monday.
Username: Rekman
Mntl-Quebec-...
Post Number: 309
COOLS*T 5000 PLATINIUM.
Nalin.. can you please give me the thread where there is explanation about the New LNB 118 & 119.. please....
I cannot see the thread.. please re-direct me to it please Nalyn. THANKS...
I need to set my receiver properly...
Username: Nydas
Post Number: 8446
Although it is in the Viewsat section, it is very informative.
http://www.ftatalk.com/showthread.php?t=80703
Username: Rekman
Mntl-Quebec-...
Post Number: 310
Thank you Nalin.... I got the thread...My dish is 33"...the New LNB will be ok with it..
Now i need the site where i can enter my adresse - location so that I can Point my dish to the right position..... I dont remember clearly ,,, it was called lyngsat... but i search on internet... but could not find the Proper one where i can enter my adress location etcccc. and the programe will tell me about the azimuth longitude latitude elvate etcccc... please give me the right site .. THANK you
Post Number: 401
All new files for DN and BEV out at www.dishkeyz.tk
Username: Nydas
Post Number: 8450
Satellite Finders (Calculators of Angles)
http://satcalculator.freehostia.com/
http://www.hollsco.com/Products/SatCalc/
http://www.remotesat.com/lookangle.htm
Satellite Charts
http://www.lyngsat*com/america.html
A good site for DISHNET info, channels,
transponders and changes etc.
http://ekb.dbstalk.com/dishlist.htm
Username: Rekman
Mntl-Quebec-...
Post Number: 311
Thank you Nalin...
Today the weathere is sunny.... I am going to work out this Dish today... otherwise meri Biwi mujhe ghar ke andar nahin aney deingey.. hahhahahaha
Username: Rekman
Mntl-Quebec-...
Post Number: 312
OK Nalin I just move the DISH... and its pointing to Echostar 61.5 West...
--And on Dish Setting ::...119 Echostar 7
LNB: Universal
Its level & quality are VERY GOOD GREEN..
--for Dish Setting ::118.8 Dish Anik F3
LNB:::.............UNIVERSAL..
Its quality & level are LOW showing Red
Please explain why the 118.8 Dish anik is red.. wat should I do.. THANKS
Username: Rekman
Mntl-Quebec-...
Post Number: 313
WAT is the actual BIN??? is there any OLD bin which is in use?
PLEASE Help thank you
Username: Nydas
Post Number: 8452
Did you get a new LNB? What LNB? What are the LNB freq, TP freq and other settings? You should be getting 119W with it - are you getting it?
Did you read in detail about your new LNB and the requirements?
Post Number: 403
All new files are out at www.dishkeyz.tk
Username: Rekman
Mntl-Quebec-...
Post Number: 314
Yes Nalin.. When the Dish point to Echostar 61.5.. I Scan and Got lots of East Indies channels... ZEE Tv Zee Cine. Sony Set Max, Sahara. etccccc... AM HAPPY with these Channels...
BUT..wat about the American Channels???... Which the Guy in the SHOP , said that I will catch East Indies channels and American channels...
Now there is East Indies But NO American channel...
In fact nathing is playing now ,. because there is NO NEW BIN ...
Username: Rekman
Mntl-Quebec-...
Post Number: 315
As I told You I boughta NEW LNB which the Shop Guy said is 118 & 119... He said in the coming month 121 wont be good.. THATS y he advice us to take the nre LNB which catch 118 & 119..(2 in 1)
Post Number: 404
MKM:
Did you scan echo 119 (Also called Echo 7/Ku)
Username: Nydas
Post Number: 8476
MKM: Don't talk in riddles, and I am not interested in what somebody said. There are currently 2-3 models which are capable of scanning 118.7/119 and give output on one cable each for two receivers, without conflict with DisEqC switch.
Give us the name and model number of the LNB. The antenna settings. The methods used so far to scan 118.7 and 119.
Username: Parathesi
Post Number: 26
Bin NORW 167 is out for cools*t 4K,5K and 6K @
www.ftabins.net
Username: Maxpayne
Post Number: 11
i have pansat 2700a. it dont works since 7 months. I dont have a new BIN. I dont have The software to download the BIN from my PC to Pansat 2700a. I have the cable connected from my PC to Pansat.
I only need New BIN file for Pansat 2700a and the software.
I need your help PLEASE.
my email: tyger79_@hotmail.com
Username: Nydas
Post Number: 8497
If it is a genuine Pansat 2700A (not a clone), you need Loader 27.02. If it is showing "b-7-5-" when turned on from back, you already have the new Boot B75 installed. You can go into Menu/system info to see what you have.
You may need to install Boot B75 if it is not there. Then you add the latest BIN 252, which was released 2-3 days ago.
Normally
http://www.future-fta.info is THE site for Pansats. Right now for reasons best known to them, you can't easily get to the info there. Try
http://www.al7bar*tk or
There are no short-cuts. Read the instructions and a few of the threads relating to the subject.
Username: Fganatra
Torrance, Ca
Usa
Hello
nalin bin for cs5k 167 is not working do know which bin is working thank you
Username: Nydas
Post Number: 8510
All of DN and BEV is down according to reports in two other forums.
Username: Mshah2006
Post Number: 50
Again they are down only after 3-4 days. I hope we can manage fixes (new bins) soon.
Username: Nydas
Post Number: 8525
For people looking for Indian channels:
Star Plus is still up.
http://forum.ecoustics.com/bbs/messages/2/453476.html
Username: Fta67
Manitoba Island
Free tv doesn’t mean hassle free tv, if you want to enjoy 500+ channels you have to be willing to put up with some bumps on the road. Remember, what doesn’t kill you will make you stronger. So sit back and relax, fixes will be coming shortly.
Username: Mshah2006
Post Number: 51
FTA67...What else can we do. Other than sit back and relax until the bin file shows up. Thank you for the support and encouragement.
Post Number: 405
DN AND BEV IS DOWN! Wait for new files at www.dishkeyz.tk
Username: Halo
Toronto, Ontario
Post Number: 394
keep checking www.dishkeys.tk for updates!
Username: Rekman
Mntl-Quebec-...
Post Number: 316
DN & BEV Are ALREADY DOWN ?????
I hadn't time to download,, and its already Out of USE????........
I think you FTA people must WORK this very HArd.. its inacceptable,...
Bin OUT and the Next Day its DOWN.. thats not FAIR....
Username: Fta67
Manitoba Island
Post Number: 7
Here are some suggestions while you wait for the next bin file:
- Play with your Xbox, PlayStation, GameCube
or whatever you have.
- Download some music or movie with Ares.
- Watch this video on Youtube:
http://www.youtube.com/watch?v=DgzHrI61CuM
- Play some solitaire on your computer
- Relax, the coders are working hard to bring you the next bin file, just give them some time. They are human not robots.
Username: Lynchmob450
Post Number: 100
