Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Problem with VSPRO & 121W
Author Thread: Problem with VSPRO & 121W
Username: Kiranap
Post Number: 12
I just loaded NEW GUI (VSPRO-080301A-II). Before loading, I did do Factory Default.
Most of the Internationals (All in My fav List) are now showing "Channel Moved". I was watching one just before I loaded NEW even that is moved.
My Setup -
VSPRO-080301A-II
Echostar 9 (121.0)
TP freq. - 11742
Any Suggestions? I have tried reverting back to OLD GUI. But now, I get same even with OLD.
One more, Everytime I try to setup Antenna Settings ... for Echostar 9 (121.0). TP Freq stays at 11742. I change it to 12132, I get Quality but it changes to 11742 on exit & I loose Q.
What am I doing wrong?
Username: Kirankumar
Kenya
Post Number: 1927
can you post your full settings for all the satellites
like lnb type freq,switch
everything you see in antenna settings
Username: Kiranap
Post Number: 13
VSPRO-080301A-II
Echostar 9 (121.0)
LNB Freq - 9750/10600
DiSEqC 1.0 - Port 2
DiSEqC 1.1 - None
Legacy SW - None
Motor Type - Disable
TP freq. - 11742
Echostar 8,10 (110.0)
LNB Freq - 11250 MHz
22Khz Tone - Off
DiSEqC 1.0 - Port 3
DiSEqC 1.1 - None
Legacy SW - None
TP freq. - 12224
Echostar 7 (119.0)
22Khz Tone - Off
DiSEqC 1.0 - Port 1
DiSEqC 1.1 - None
Legacy SW - None
TP freq. - 12224
Kenya
Post Number: 1929
for echostar 9 > change lnb freq to 11250,
and then transponder freq to 11457
post results
Kenya
Post Number: 1930
or try different tran freq once you set lnb to 11250
Username: Lookekhoshshans_1356
Tehran, Tehran
Iran
Post Number: 96
http://forum.ecoustics.com/bbs/messages/2/456623.html
Username: Madflea168
Post Number: 302
the channels may moved from 121 to 118, you will need a dual 118/119 lnb or dn's repoint kit to capture the 118.
also, put 119 on port 1, 110 on port 2, 121 or future 118 on port 3.
for my vs, I had 10750 to work on 121 before and 118 now, 10600 did not work on me.
Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Problem with VSPRO & 121W [ « Previous ] [ Next » ]
