Home > Message Board > Home Video > Rear Projection TVs > Archive through March 16, 2008 > Samsung problems
Author Thread: Samsung problems
Username: Milpol78
I have a samsung 55inch tv model hc p5252w its a few yrs old turned it on the other day and everything is zoomed in cuts everything off on outer edges. it does have a picture size button but scroll through the sizes and it only changes when on zoom1 and 2 which makes it get closer. all others remain the same even though shouldnt. so im guessin its stuck somehow any ideas?
Username: Ovadoggvo
Post Number: 110
Shane,
Enter the service menu and do a factory reset... I think this should fix your problem.. Instructions on getting to service menu can be seen here:
http://fixyourdlp.com/blog/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter -counter/
Username: Milpol78
thanks for the tip i was able to get in and do a factory reset but still did not work any other ideas that might fix the problem?
Username: Ovadoggvo
Post Number: 115
Does this happen with cable, dvd, or all inputs?
Username: Milpol78
it happens with all inputs
Home > Message Board > Home Video > Rear Projection TVs > Archive through March 16, 2008 > Samsung problems [ « Previous ] [ Next » ]
