Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Level & Quality not coming in strong
Author Thread: Level & Quality not coming in strong
Username: Ferrarifire
Post Number: 59
on my colsat5000 my level quality keeps coming in and out. but the weather outside is fine. i was wondering would that be from my dish or from the receiver or cause the file is about to go down? i dont get it. and like 2 channels come in really good but the others dont. i have a dish 500. only the international dish though. and i scan 91.0 Nimiq 1,3 to receive my channels. my freq is set at [1]12.224 GHZ, symbol rate is 20.000 MS/s, polarization V, do i need to change anything??
Username: Kirankumar
Kenya
Post Number: 1910
post all your settings
Post Number: 60
91.0w Nimiq 1,3
LNB Power ON
LNB Type Single
LNB Freq 11.200
22KHZ OFF
DiSEqc Switch OFF
Legacy SW OFF
Username: Craneop37
Post Number: 18
sounds like your dish might be out of alignment try to repoint your dish
Kenya
Post Number: 1913
change lnb freq to 11250
Post Number: 61
Im always outside messing with the dish cause its on my porch and i have easy access to it. it sometimes works sometimes it does nt. and everytime i change the freq and save it never stays the same. and right now 11.200 is coming in better than 11.250
Post Number: 62
now 5 mins later 11.250 is coming in better than 11.200 so i dont get it
Kenya
Post Number: 1916
go to motorised settings and change frequency.then when you get best quality,save it and do auto scan
Post Number: 64
ok thank you. 1 more Q is there a website were i can figure out what channel im watching. like for channel 6555 tv 5555 it has ufc on but im not sure what it is
Username: Hardrockstriker
Post Number: 1023
Ferrari, try: LNB-Type = OSC-DP, Freq = 11250, also you should assign disecq ports to the dish's internal switch (I think port 1 is sat 91 and port 2 is sat 82).
Then try to re-aim your dish.
Kenya
Post Number: 1921
go to the lyngsat site
Post Number: 1024
Lyngsat has channel maps for you.
lyngsat*com (replace * with a dot)
Post Number: 65
alright cool thanks a lot guys
Username: Angie_wedgewood
Post Number: 66
Actually I have a CS5000 and my signal strength has been coming in an out all day too. And right now it's basically at zero on all of the channels, and it was completely fine a couple of minutes ago (plus the weather outside is beautiful). So I'm thinking it might not be your dish alignment...
Username: Lklives
Post Number: 14174
bad cable and connections will cause that...hardware issue..
Username: Lklives
Post Number: 14175
also its solar conjunction time...
Post Number: 67
I find it hard to believe it can be a hardware issue when it's perfectly fine one minute and then gone another, and then back again for several hours and then goes out again.. That doesnt really make any sense. Especially when it's happening to more than one person with the same reciever. Doesn't that seem a little too ironic just to be a hardware issue? I dunno maybe I'm completely wrong, but it'd be interesting to know what's happening with the other CS5000's out there..
Kenya
Post Number: 1933
mine works just great
Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Level & Quality not coming in strong [ « Previous ] [ Next » ]
