Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Viewsat Ultra Missing Channels
Author Thread: Viewsat Ultra Missing Channels
Username: Pu_da_munda
Post Number: 60
I hv viewsat ultra and all Indian channels are not showing since yesterday. Can anyone tell me whats the problem?
Username: Plymouth
Quebec city, Quebec
Post Number: 502
Sidhu Which sat and channel
Post Number: 61
DN and all Indian channels like Zee, SET, MAX , ETC punjabi etc....
Its keep on saying autoroll in process..... and nothing is displayed for these channels.
Username: Plymouth
Quebec city, Quebec
Post Number: 504
Dish have 61.5 110 118.7 119 121 148
Which one
Post Number: 62
echostar 8.10
Post Number: 63
echostar 6,8 110.0W
Post Number: 66
Plymouth can u help me getting the channels?
Username: Plymouth
Quebec city, Quebec
Post Number: 505
# channel please i can check if work for me and
give freq for scan
Username: Kirankumar
Kenya
Post Number: 1911
Sidhu,
post your settings fao all satellires you have so we can help
Post Number: 67
0617, 0618, 0619,0620, 0622, 0612, 0576, and so on...
Kenya
Post Number: 1912
no no no
go to menu> Satellite
then you will see settings
like frequency
lnb type
switch
etc etc
post everyting
Post Number: 68
SAT settings for echostar 6,8 110.0W
LNB Power : ON
LNB TYPe : OCS-DP
LNB Freq : 11250
22KHz : Off
TP Freq : 12224
DisEqc1.0 : None
If you need any other information please let me know
Username: Plymouth
Quebec city, Quebec
Post Number: 506
It's same for me, i do a blind scan and i reply.
Do a blind scan too
Kenya
Post Number: 1914
Sidhu,
do you have just one satellite?
because if you do then you are not going to get Indian on this
Post Number: 69
No, I have Echostar 3 and echostar 7 also
Username: Plymouth
Quebec city, Quebec
Post Number: 507
African is it possible Indian is on 61.5w and not on 110w
Kenya
Post Number: 1917
go to settings again and post the settinga like you did for this one
just change the first line for the satellite
your problem is with switch settings
if you post i will fix it for you
Kenya
Post Number: 1918
DisEqc1.0 : None
change this
on all 3 sats
then next line will come up
for 119 > 1 OFF OFF
for 110 > 2 off off
for 61.5> 3 Off off
Post Number: 70
African you need the setting for Echostar 3 and Echostar 7? Just give me 2 mintues please
Kenya
Post Number: 1919
change this
DisEqc1.0 : None
on all 3 sats
for 119 > 1 OFF OFF
for 110 > 2 off off
for 61.5> 3 Off off
Username: Plymouth
Quebec city, Quebec
Post Number: 510
This channel are on 65.1w
I confirm
Post Number: 71
I tried to do AutoDiscEqc for all satellite but it doesnt work.
Kenya
Post Number: 1922
if you go to disceqc
and click on it then you can change to 1.1 or something like that
Username: Plymouth
Quebec city, Quebec
Post Number: 513
Sidhu listen African he help you for this
I have one lnb and motor my switch setup is different
Post Number: 72
it says Port 1 to Port 4
Kenya
Post Number: 1923
ok
set 119 on port 1
110 on port and 61.5 on port 3 and it should work
Post Number: 73
I can see all other channels on 61.5 like Boomerang, Movies, PPV but all Indian channels are missing/not showing?
I sincerely thanks Plymouth and African for your effords and time.
Post Number: 74
Sorry guys, I changed the setting as mentioned but still cannt see these channels.
Username: Plymouth
Quebec city, Quebec
Post Number: 515
Do a blind scan on sat where you have lost channel
that recovered it
Post Number: 75
I hv all the channels in the list but on selection its keep on doing autoroll processing..
Post Number: 76
Even I hv installed the factory setting file and new bin file...but all in vain
Username: Plymouth
Quebec city, Quebec
Post Number: 516
OK try to switch off rear panel 5 secs (hard boot)
if dont work go to channel scan and delete sat and reinstall it
Post Number: 77
I turned off the rear panel and after reboot it says no channels and i have to do blind scan.. its in progress.. lets see
Username: Plymouth
Quebec city, Quebec
Post Number: 518
Sidhu between and before each install bin do a hard reboot 5 secs that why you box is in trouble
you need to empty intern memory like a computer
Username: Jayson
Post Number: 189
sidhu......you need to make sure that you have the satellites in the right port just as you assigned them in the settings.....also make sure your LNB is Dish pro....if not you have to change the LNB Type setting to standard........
Username: Rzkaps
Toronto, Ontario
Hi Guys,
I have Viewsat Ultra and like Sidhu, I am not getting Indian channels and American channels like ABC, which we used to get with FORTEC receiver earlier.
I kept playing with the settings and now my Satellite is showing EChostar 3 360W instead of 61.5. How do I change this back to 61.5. I have only one dish.
I am getting European and Arabic channels. Do you have to change any settings to get the normal DN channels.
The channel list is showing so many channels, but when you click on the channel, it keeps searching for the signal.
Please help
Username: Plymouth
Quebec city, Quebec
Post Number: 524
Rashida go to menu
installation 0000 pin code
antenna setup
go to motor selected Usals enter
supposed to see on third lines
" echostar 3 61.5w
if not arrow up and write "615" and down arrow for "w" and "ok
exit save
reply please
Username: Plymouth
Quebec city, Quebec
Post Number: 525
Rashida how many dish you have wich sat you went give a little more information please
Username: Plymouth
Quebec city, Quebec
Post Number: 526
""The channel list is showing so many channels, but when you click on the channel, it keeps searching for the signal.""
You need to delete sat and rescan this channel are encrypted or from another sat etc.
I have same problem when test scanning
Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Viewsat Ultra Missing Channels [ « Previous ] [ Next » ]
