Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > 2500 pansat
Author Thread: 2500 pansat
Username: Saado7
Post Number: 30
i need help with my 2500 i tried to convert it to 2700 but did no work now it does not switch on dead no signes of life anything i can do to bring it back to life?? thnx .
Username: Indopak
Post Number: 84
i just bought a reciever and i need the converting file... can someone tell me the link for it?
Username: Le74nguyen
Perris, Ca
Usa
Post Number: 153
what's you have it? pansat clone?
Username: Oleg1474
Florida
Usa
Post Number: 1018
www.fta(#4)dummies,com
Username: Oleg1474
Florida
Usa
Post Number: 1019
what you have to do is install the pansat 2700 factory bin you can get it here http://www.pansatusa.com/download/2500/2700A.zip
Then upload the b80 update firmware you can get it here http://www.pansatusa.com/download/2700A(b-80)/2700A(b-80).zip
These are the instructions I used and it worked.
All files are in the zip file attached.
1. Do a factory reset.
2. Load factory bin file
3. Start up the loader v27.02 (THIS IS A NEW LOADER and is required for all B75 level files.
4. Select the file BOOT 2700A.......0301.bin and select BOOT FILE ONLY
5. Power the receiver ON at the rear switch and start the download. The front display will show B75 moving across if successful when finished.
6. Open the API file X87_BL_080301_B75_273_API.bin and select API file on the loader. (NOTE: Any api file after 10 Mar 07 should work if/when they are later issued) When complete, the box should say B80 and then switch to "ON" if you followed the instructions completely. If you did not return your box to factory state first, it will switch to a channel number instead of "ON" but may also fail. Shortcuts are user decisions.
DO NOT power off until steps are completed. Failure to follow instructions can result in potential damage.
Username: Oleg1474
Florida
Usa
Post Number: 1020
as soon as i get the access from hector,, i can upload the file i have to convert panst2500 to 2700 in English and Spanish. it works just fine. i have done this to 2 pansats and it works great. you must read the directions very carefully or you will mess your box up, read read read then read again. then do it.
Username: Jwl1
Post Number: 228
Copy and pasted from one of Nalin's postings.
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest files BL253T_Lightning_serial.bin
Some jtag files are also included.
The full kit is in full_kit253A.zip or later. Download and unzip in a new jvvh directory.
Read the instructions in the Instructions.doc file.
Also available separately in All_253.zip file with all the conversion 253 BINs released so far.
http://public.box.net/2500_full_kit
Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > 2500 pansat [ « Previous ] [ Next » ]
