Thread: Viewsat Ultra frozen |
Bronze Member Username: Dhabu
Boston,
Ma
Usa
Post Number: 12 Registered: May-06
| Posted on Saturday, March 01, 2008 - 03:01 pm: |
My Ultra is grozen either on 0 or 1 0r 6 on the front. When I go to upload the new bin through the usb it keeps on saying intializing usb and nothing happens. It is totally frozen. I cannot load anything. When I use the cble to load through the loader it keeps on saing intializing and gives a error code. How can I resolve this problem. Thanks |
Gold Member Username: Hawaiian_time
Kanaka freak...
Post Number: 1851 Registered: Apr-06
| Posted on Saturday, March 01, 2008 - 03:13 pm: |
First of all, make sure the cable from the dish is disconnected. Do a hard reboot, then try loading with cable again. |
Silver Member Username: Plymouth
Quebec city,
Quebec
Post Number: 475 Registered: Jan-08
| Posted on Saturday, March 01, 2008 - 03:34 pm: |
Try it: In your package box with receiver is furnish a cable RS-232 you must download factory bin with the cable from your computer . Go to: <http://viewsatusa.com/support.htm> download this 2 files: PVR Loader v11 - Firmware Updater ( Serial)you install this one on computer VS2000 ULTRA Factory Bin File - V132 for download with the loader in your receiver Sorry Hawaiian |
Gold Member Username: Kirankumar
Kenya
Post Number: 1902 Registered: Oct-07
| Posted on Saturday, March 01, 2008 - 04:13 pm: |
any results? |
Bronze Member Username: Palau
Hercules,
Coahuila
Mexico
Post Number: 18 Registered: Jan-08
| Posted on Sunday, March 02, 2008 - 10:36 am: |
I got my Ultra working now by following the instructions given here. I diconnected the lnb cable and then loaded factory bin 132 through my usb port and then loaded new vs bin. I still can not get cnn or western channels, any ideas? |
Hercules,
Coahuila
Mexico
Post Number: 20 Registered: Jan-08
| Posted on Sunday, March 02, 2008 - 10:38 am: |
sorry, I forgot to say Thank you! |
Bronze Member Username: Baileygirl
Post Number: 25 Registered: Dec-07
| Posted on Sunday, March 02, 2008 - 07:03 pm: |
Try disconnecting your sat. cable again then turning the receiver off in the back. Then turn it on and wait for the receiver to reboot, then once it is rebooted, (don't reconnect your sat. cable yet, just have the receiver hooked to your tv) then load the latest viewsat file for March 2008, wait for it to load, and then turn the receiver off in the back again. Reconnect your satellite cable to the receiver. Turn the receiver back on. Flip to channel 120 and wait until you get the picture to come back on. It may take 10 -20 minutes. Just wait, it will say "autoroll" but just wait until you see a picture on your tv. This may clear up any issues you are having with not getting the cnn or western channels. Hope this helps, it helped me. |
Boston,
Ma
Usa
Post Number: 13 Registered: May-06
| Posted on Sunday, March 02, 2008 - 09:14 pm: |
I thank all of you and I have done exactly as you have said by loading the factory bin and reloading with the current Bin and everything is in working order. Thanks so much. |
