Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Anyone know anything about 3X4 Switch?
Author Thread: Anyone know anything about 3X4 Switch?
Username: Ubba
Post Number: 129
Have 3 receivers, but need the 3X4 switch for two receivers as one of them is not working due to the loop effect. VS Ultra getting the cable from the Satellites is working, the other one getting it from the first VS Ultra is no longer working. Have 2 satellites. Thanks for your help.
Username: Kirankumar
Kenya
Post Number: 1891
Lisa,
very simple
get a dp34 switch
it has 3 inputs > so you can hook up 3 satellites
and it has 4 outputs > so you can hook up 4 receivers
they are about $30 on e bay
Username: Ubba
Post Number: 131
So I have to buy an extra Satellite?
Kenya
Post Number: 1893
NO NO NO
just a dp34 switch
what i meant was that if you wanted it could have UPTO 3 satellites on it
in your case you will hook your 2 satellites and 3 receivers and you should be good
Username: Det
Post Number: 56
which echo or anik is 118.7 is on at pansat 2700a on dish network
Username: Lklives
Post Number: 14121
Anik 3
Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Anyone know anything about 3X4 Switch? [ « Previous ] [ Next » ]
