Thread: Digital Broadcasting |
Platinum Member Username: Lklives
Post Number: 14109 Registered: Jan-06
| Posted on Saturday, March 01, 2008 - 11:02 am: |
On February 17, 2009, federal law requires that all full-power television broadcast stations stop broadcasting in analog format and broadcast only in digital format. Here’s what these requirements will mean for you and your television viewing. -------------------------------------------------------------------------------- Why Are Broadcast TV Stations Switching to All-Digital? Congress mandated the conversion to all-digital television broadcasting, also known as the digital television (DTV) transition, because all-digital broadcasting will free up frequencies for public safety communications (such as police, fire, and emergency rescue). Also, digital is a more efficient transmission technology that allows broadcast stations to offer improved picture and sound quality, as well as offer more programming options for consumers through multiple broadcast streams (multicasting). In addition, some of the freed up frequencies will be used for advanced commercial wireless services for consumers. What Do I Need To Do To Be Ready For The DTV Transition? What you need to do depends on the source of your television programming, whether you receive programming over-the-air or from a paid provider such as a cable or satellite TV company. How Do I Receive Digital Broadcasts If I Don’t Subscribe To Cable Or Satellite? If you receive only free over-the-air television programming, the type of TV you own, either a digital TV or an analog TV, is very important. Consumers who receive only free over-the-air television may view digital programming through a TV set with a built-in digital tuner (integrated DTV) or a digital-ready monitor with a separate digital tuner set-top box. (Both of these digital television types are referred to as a DTV). The only additional equipment required to view over-the-air digital programming with a DTV is a regular antenna, either on your roof or a smaller version on your TV such as “rabbit ears.” If you have an analog television, you will have to purchase a digital-to-analog set-top converter box to attach to your TV set to be able to view over-the-air digital programming (see “What About My Analog TV?” below). How Do I Know Whether I Own a DTV? As of March 1, 2007, all television receivers shipped in interstate commerce or imported into the United States must contain a digital tuner. In addition, effective May 25, 2007, the Commission required sellers of television receiving equipment that does not include a digital tuner to disclose at the point-of-sale that such devices include only an analog tuner, and therefore will require a digital-to-analog converter box to receive over-the-air broadcast television after the transition date. Retailers must inform consumers by prominently displaying the following text if they are selling TV equipment with only an analog tuner: This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation’s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission’s digital television website at: www.dtv.gov. Therefore, after May 25, 2007, all television equipment being sold should contain a digital tuner, or should be identified at the point-of-sale as not having one. Be sure to look for this label if you are purchasing a new TV. As for how to determine whether your television equipment purchased prior to May 25, 2007 is a DTV, many DTVs and digital television equipment will have labels or markings on them, or statements in the informational materials that came with them, to indicate that they contain digital tuners. These labels or markings may contain the words “Integrated Digital Tuner” or “Digital Tuner Built-In.” “Receiver” may be substituted for “Tuner,” and “DTV,” “ATSC,” or “HDTV” (high definition television) may be substituted for “Digital.” If your television equipment contains any of these labels or markings, you should be able to view digital over-the-air programming without the need for a digital-to-analog converter box. (Remember, you do not need an HDTV to view free over-the-air digital programming. As long as your television equipment contains a digital tuner, you can view over-the-air digital. An HDTV is only necessary if you want to view digital programming in “high definition.”) You should also check the manual or any other materials that came with your television equipment in order to determine whether it contains a digital tuner. If your television set is labeled as a “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready,” this does not mean it actually contains a digital tuner. Thus, you still will likely need a separate set-top box which contains a tuner in order to view programs in the new digital TV transmission standard (which includes HDTV formats) on such a set. Over-the-air digital set-top boxes can be purchased at retail stores. Cable and satellite TV providers also sell or lease digital set-top boxes for their specific services. (Note: the digital set-top box described here is not the same as the NTIA program digital-to-analog converter box, described below, used to convert free over-the-air digital broadcasts for viewing on an analog TV set.) If your television set is labeled as “analog” or “NTSC,” but is NOT labeled as containing a digital tuner, it contains an analog tuner only. If you cannot determine whether your television set or other television equipment contains a digital tuner, you are advised to check your equipment for the manufacturer name and model number, and then contact your consumer electronics retailer, or the manufacturer, to determine whether it contains a digital tuner. This information also may be available online through the manufacturer’s website. Because most broadcast stations in all U.S. television markets are already broadcasting in digital, consumers are further advised to contact their local broadcast stations to determine the channel numbers on which the stations are broadcasting digital programming. Consumers should then ensure that their televisions are set up to receive over-the-air programming (as distinguished from the signals of a paid provider such as cable or satellite TV service), and then tune to the over-the-air digital channels to see if they can receive the digital broadcast programming. What About My Analog TV? Will It Still Work? After February 17, 2009, you will be able to receive and view over-the-air digital programming with an analog TV only by purchasing a digital-to-analog set-top converter box. Between January 1, 2008, and March 31, 2009, all U.S. households will be able to request up to two coupons, worth $40 each, to be used toward the future purchase of eligible digital-to-analog converter boxes. Eligible converter boxes are for the conversion of over-the-air digital television signals, and therefore are not intended for analog TVs connected to a paid provider such as cable or satellite TV service. The National Telecommunications and Information Administration (NTIA) is administering the coupon program. For more information, visit the NTIA website at www.dtv2009.gov. The Commission’s DTV website, www.dtv.gov, also provides information for consumers on the upcoming digital-to-analog converter box coupon program. More detailed information regarding NTIA’s coupon program, what digital-to-analog converter boxes will be eligible, where and when they may be purchased, and the related costs involved will be provided by the Commission and NTIA as the commencement of the coupon program on January 1, 2008, approaches. If I Already Have an Antenna, Do I Need a New One to View the Digital Signals? A special antenna generally is not needed to receive digital signals. You may have antenna issues, however, if your current antenna does not receive UHF signals (channels 14 and above) well, because most DTV stations are on UHF channels. In such a case, you may need a new antenna or to add a UHF section to your existing antenna system. This equipment should be available at most bricks-and-mortar and Internet consumer electronics retailers. How Do I Receive Digital Broadcasts If I Subscribe To Cable Or Satellite? If you receive cable or satellite television service, contact your cable or satellite provider about any additional components, such as a digital set-top box, that you may need to watch digital broadcast programming. If I Buy a DTV, Will My VCR, DVD Player, Camcorder, Video Games, Or Other Equipment Still Work? VCRs, DVD players, camcorders and video games will continue to work, even if they are only analog-capable. Such equipment, however, may not provide digital-quality picture and sound. Manufacturers are producing a number of different connectors to hook equipment together and improve picture and sound quality. Check with your equipment retailer to determine the types of connectors that will work with your equipment. How Much Will DTV Improve My TV Viewing? While picture quality will vary according to whether you watch digital programming in high definition (HDTV) or standard definition (SDTV) format, over-the-air digital programming provides a better viewing experience than over-the-air analog programming, as long as you have good quality reception through your antenna. How Much Will a DTV Cost? Prices vary depending on the many features and options available to consumers, including format, display technology, and screen size. Display technology choices include cathode ray tube screens, rear projection TVs, front projection TVs, and flat panel TVs. Flat panel TVs, often the most expensive, can use either a liquid crystal display (LCD) or plasma screen technology. Screen size is measured diagonally across the screen, and the larger the screen, generally the more expensive the TV. To determine the equipment and features that are right for you, learn about DTV from our Web Site and discuss your options with your retailer. For More Information For more information about the DTV transition, go to www.dtv.gov, which also provides links to several other informative websites, or contact the FCC’s Consumer Center by e-mailing dtvinfo@fcc.gov; calling 1-888-CALL-FCC (1-888-225-5322) voice or 1-888-TELL-FCC (1-888-835-5322) TTY; faxing 1-866-418-0232; or writing to: Federal Communications Commission Consumer and Governmental Affairs Bureau Consumer Inquiries and Complaints Division 445 12th Street, SW Washington, DC 20554. |
Bronze Member Username: Bonguemikaadu
Post Number: 15 Registered: Nov-07
| Posted on Saturday, March 01, 2008 - 11:07 am: |
LK, is there a new bin for VS PVR 7000? |
Post Number: 14110 Registered: Jan-06
| Posted on Saturday, March 01, 2008 - 11:22 am: |
Some satellite owners still seek out this sort of programming on their own, but today, most satellite TV customers get their programming through a direct broadcast satellite (DBS) provider, such as DirecTV or DISH Network. The provider selects programs and broadcasts them to subscribers as a set package. Basically, the provider's goal is to bring dozens or even hundreds of channels to your TV in a form that approximates the competition, cable TV. Unlike earlier programming, the provider's broadcast is completely digital, which means it has much better picture and sound quality (see How Digital Television Works for details). Early satellite television was broadcast in C-band radio -- radio in the 3.7-gigahertz (GHz) to 6.4-GHz frequency range. Digital broadcast satellite transmits programming in the Ku frequency range (11.7 GHz to 14.5 GHz ). http://electronics.howstuffworks.com/satellite-tv2.htm |
Gold Member Username: Donnie1973
Post Number: 2778 Registered: May-06
| Posted on Saturday, March 01, 2008 - 01:04 pm: |
the govt will be giving a little money to some people to help with the additional costs of these digital boxes. google it |
Post Number: 14117 Registered: Jan-06
| Posted on Saturday, March 01, 2008 - 02:05 pm: |
DTV Transition and the Coupon Program https://www.dtv2009.gov/AboutProgram.aspx What is the digital television transition? At midnight on February 17, 2009, all full-power television stations in the United States will stop broadcasting in analog and switch to 100% digital broadcasting. Digital broadcasting promises to provide a clearer picture and more programming options and will free up airwaves for use by emergency responders. What is the TV Converter Box Coupon Program? Congress created the TV Converter Box Coupon Program for households wishing to keep using their analog TV sets after February 17, 2009. The Program allows U.S. households to obtain up to two coupons, each worth $40, that can be applied toward the cost of eligible converter boxes. A TV connected to cable, satellite or other pay TV service does not require a TV converter box from this program. Consumers have a variety of options. Options to explore include: Keep your existing analog TV and purchase a TV converter box. A converter box plugs into your TV and will keep it working after Feb. 17, 2009, or Connect to cable, satellite or other pay service, or Purchase a television with a digital tuner. |
