Thread: How to get star plus on Nfusion |
Silver Member Username: Imars99
Post Number: 102 Registered: Aug-06
| Posted on Saturday, March 01, 2008 - 01:00 am: |
How to get star plus on Nfusion ?Pl help.where are you Sada? |
Silver Member Username: Leafs
Post Number: 507 Registered: Oct-07
| Posted on Saturday, March 01, 2008 - 01:11 am: |
How to add STAR PLUS on Nfusion! -------------------------------------------------------------------------------- b{Here's Hows to add STARPLUS On you Nfusion 1. Go to Installation 2. Go to Channels Scan. 3. Go to Add TP (last option) 4. Choose as below Frequency: 12443 Polarization: Auto Symbol Rate: 20000 5. Then go to Add channel. (choose as below) Channel Name: Star Plus (or any, doesnt matter) Video PID: 5666 Audio PID: 5667 PCR PID : 5666 6. Press Manu Two Times and it will same channel on memory. 7. Press Guide and choose channel No. 605 8. DONE! you will see guide in other language, but you will see its "STAR PLUS" |
Gold Member Username: Saqeeb9000
Post Number: 2561 Registered: Oct-07
| Posted on Saturday, March 01, 2008 - 01:29 am: |
SORRY FOR LATE RESPONDING.. SETTING ARE SAME AS DONLAD DESCRIBED ABOVE.. DO POST THE RESULTS.. |
Post Number: 509 Registered: Oct-07
| Posted on Saturday, March 01, 2008 - 01:32 am: |
SADA don't worry about it... you help a lot around here... we can't expect you to be here 24/7 ... whoever knows the answer should give it... |
Post Number: 2563 Registered: Oct-07
| Posted on Saturday, March 01, 2008 - 01:33 am: |
Post Number: 2564 Registered: Oct-07
| Posted on Saturday, March 01, 2008 - 01:34 am: |
ECOSTICS MAY BE WITH STATUS...ONLY |
Post Number: 103 Registered: Aug-06
| Posted on Saturday, March 01, 2008 - 11:19 am: |
Thanks Donald and Sada.Its working but not on 605. |
