Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Need help but people started cursing,...
Author Thread: Need help but people started cursing, please help me with VS Ultra issue
Username: Ubba
Post Number: 108
I did everything I was supposed to do and things were unfrozen, added new bin, but nothing happened. Channels were at quality 0. So, I did a factory reset and have tried to download channels, but am getting nothing. I wrote a thread before, and people ended up swearing and cursing at each other. Please only those who really want to help me answer. thank you
Username: Ong_tu
Post Number: 340
Lisa. go to this site and you will be helped without people cursing you.Just post the same question.
http://www.all-gadgets.net/forums/index.php
Username: Saqeeb9000
Post Number: 2559
ok lisa calm down and don't listen to ongtu..
install a factory bin (its different than factory reset).. download a factory bin, reinstall the bin and then post the results good luck..
Username: Metallica
Post Number: 212
Lisa whenever you press the factory reset you have to go back to menu..installation..antenna setup and reconfigure your SAT setting again like the one B4 you have or you will not get any signals or quality at all..and i hope you remember your old setting..LOL.
Username: Ubba
Post Number: 110
Thank you Sada. I will try and let you know. I truly appreciate your help.
Username: Kirankumar
Kenya
Post Number: 1853
i have been trying to tell her to post the settings so i can help,
it does not need resetting
just the settings are wrong
Username: Ubba
Post Number: 112
I only have the LNB and others written down, nothing else is. While it's trying to download the channels, the frequencies are changing, but no channels are coming. Help again.
Kenya
Post Number: 1855
you mean it is downloading channels right now?
Username: Ubba
Post Number: 113
no, it's not doing anything except saying % but no channels are being downloaded. It says nochannel at the front. I don't know what to do anymore.
Kenya
Post Number: 1856
ok go to menu>satellite and make notes of all settings
then change the satellite on to and new settings will appear for that satellite make a note of that as well and post so i can help
Username: Metallica
Post Number: 214
post your SAT setting...post your SAT setting..
please..please..pretty please..so i and African
can help or we are blind..
Username: Luser
Post Number: 85
Using your remote hit menu then hit ok on antenna setup scroll to one of the two sats your pointed at. Now if you have 2 sats then you have a switch and lnb type. If you know the type your using great or scoll the different options looking for the one that gives the best quality. Once you have q the name of the sat appears make sure it matches the one whos settings your changing otherwise change the diseq or legacy choices.
Username: Ubba
Post Number: 114
Satellite: Echostar 3 61.5W
LNB Power: On
LNB Type: Standard
LNB Freq. 11250
22KHz: Off
TP Req.: 12297
DiSEqC 1.0: Port 1
Motor: Off
Legacy SW: None
Kenya
Post Number: 1859
change tp freq to 12326 and see if you can see any diff
then post settings for any other birds you have
Username: Ubba
Post Number: 115
No change, sorry post settings for what exactly? am not familiar with many terms.
Kenya
Post Number: 1860
like on the top line you see
Echostar 3 61.5
if you have more than one satellite change that until you see the correct satellite and post settings.
also slowly change tp freq on 61.5 and see if any one of them makes good quality.if it does then save that
Username: Plymouth
Quebec city, Quebec
Post Number: 451
Aficain i had same problem today when test old bin and put new release factory bin v0132 at viewsatusa.com/ support and new bin and signal comeback if you said to her maybe?
Thanks
Username: Metallica
Post Number: 215
try to change the (LNB type)and the TP Freq change to 12224...and try to change the DiSEqC port too..see anything come up.
Kenya
Post Number: 1861
PLymouth that is what i was going to suggest next.thanks
but lisa if you do that then switch OFF your box and remove co ax coming from satellite,then load factory bin and then latest bin then hook up coax again
Kenya
Post Number: 1862
Metallica,
it is not lnb problem,but my post above should fix it,because the ecm on vs today locked the units up,
and crazy things were happening
Username: Ubba
Post Number: 116
I loaded a factory bin and latest bin, I already did those. I tried to put in 12224, but couldn't find that TP frequency. No other TP frequencies showed me any quality.
As for the satellites, I only have echo star 3 and echo star 8.10, which I put on diseq port 2.
Kenya
Post Number: 1864
Lisa,
if you have just one satellite then turn diseq off
Username: Ubba
Post Number: 117
TP 12224 comes on the echostar 8.10.
So echo star 3 is on Diseq port 1
echo star 8.10 is on Diseq port 2
Nothing is happening whatsoever.
Kenya
Post Number: 1865
sorry ignore the last post
Kenya
Post Number: 1866
Lisa,
can you post all settings for echo 8 please
Username: Metallica
Post Number: 216
African yes i know about the locked up today.but when you downLOAD the new factory bin and the lastest bin it all working normal again..but after Lisa finish loading those new bin and she press factory reset now all she need is to reconfigure the SAT setting again that all..but the problem is she don't know how...just don't press the factory reset again next time..LOL
Username: Plymouth
Quebec city, Quebec
Post Number: 452
Sometime we dont see signal i dont know why
and after autoscan that appear Maybe?
Username: Ubba
Post Number: 118
Echostar 8.10 110.0W
LNB Power: On
LNB Type: Standard
LNB Freq: 11250
22Khz: Off
TP Freq: 12224
DiSEqC: Port 2
Motor: Off
Legacy SW: None
Kenya
Post Number: 1867
Lisa,
all your settings look good,
could you check that the coax coming from sat is hooked up on the right terminal,but make sure box is OFF if you remove or connect the cable
Username: Metallica
Post Number: 217
Lisa it looking right to me.
can you go and download the lastest bin again.
make sure is this 1..
PFTAUSW-080301U DN & Bev...
Username: Plymouth
Quebec city, Quebec
Post Number: 453
Hey Lisa the setting for high Lnb is 12239 for 110w with small dish on 12297 signal is very poor
Username: Ubba
Post Number: 119
did that, nothing
Kenya
Post Number: 1868
Plymouth,
she has 12224,which should be good for 110 on basically any dish,something else is going on here,cable or switch
Username: Plymouth
Quebec city, Quebec
Post Number: 454
12326 for 61.5W
Username: Ubba
Post Number: 120
My Dad's viewsat is working fine on same frequencies. I'm getting processing 55% and more and no channels are coming down
Kenya
Post Number: 1869
correct
Username: Ubba
Post Number: 121
So, what do I do with mine. I've done the factory reload before and factory resetting and never had this problem, now I can't get any channels. Any suggestions, I'm panicking right now.
Username: Plymouth
Quebec city, Quebec
Post Number: 455
Africain 12224 is for Bev the signal is better on 12239
Username: Ubba
Post Number: 122
I have DN
Username: Plymouth
Quebec city, Quebec
Post Number: 457
Lisa the factory bin is this the brand new from viewsatusa.com/support
Username: Ubba
Post Number: 123
Guys, I'm getting zippo, no channels, what do I do? I'm going crazy
Kenya
Post Number: 1871
Lisa,
you don't need to panic,because as long as your receiver is powering up there is a cure for it.
i don't know where you are but it is dark on the east coast here.
what i need next is a direct connection from any one satellite to receiver,by passing the switch,so we are trying to eliminating bad switch
Kenya
Post Number: 1872
Plymouth,
12224 is good for dn as well,i have it here
Username: Plymouth
Quebec city, Quebec
Post Number: 460
Maybe check if the small pin connector inside RG-6 is folded
Username: Plymouth
Quebec city, Quebec
Post Number: 461
I know but the signal is lower then 12239 i use all the time 12239
Kenya
Post Number: 1873
yeh now it seems a cable or switch issue,i am guessing more switch then cable,because when ecm hit today it locked a lot of vs and did a lot of crazy things
the good thing thing is that her unit is alive
Username: Plymouth
Quebec city, Quebec
Post Number: 462
Try it before:
Kenya
Post Number: 1874
Plymouth,
she is not getting anything on 61.5 as well so that is not the problem
Username: Ubba
Post Number: 124
So why after the factory reset did everything go wrong. Should I retry to download the factory bin from viewsat usa or maybe another factory bin that can fix this no channel thing?
Username: Plymouth
Quebec city, Quebec
Post Number: 463
All sat no signal or just one
Kenya
Post Number: 1876
Lisa did you download factory bin 132?
Username: Plymouth
Quebec city, Quebec
Post Number: 464
on 61.5 the setting is tp freq 12384
Username: Birdwatcher
Post Number: 725
I THINK YOU SHOULD GO DOWNLOAD ON IT
Kenya
Post Number: 1877
Plymouth,
she tried other frequencies on that,still same
Username: Ubba
Post Number: 125
yes, I downloaded factory bin 132 and pin is fine. Nothing is wrong. I tried everything.
Username: Plymouth
Quebec city, Quebec
Post Number: 465
Ok Africain All sat no signal or just one
Kenya
Post Number: 1878
Lisa,
the last thing is to try a direct connection from satellite to receiver on any one satellite,
if you get signal & quality then your switch got fried
Kenya
Post Number: 1879
ALL
Username: Ubba
Post Number: 126
Ok, will try. Thanks guys for all your help. Right now it's very late, so I will see what I can do, if not will try early am and will let you know. I really really appreciate your help.
Kenya
Post Number: 1880
good night,
sorry could not fix it for you tonight,but post results tomorrow please
Username: Plymouth
Quebec city, Quebec
Post Number: 466
How is Meteo? I change a switch because water come in the problem come after disconnect approx 3 hours the lnb
Username: Plymouth
Quebec city, Quebec
Post Number: 467
Good night Lisa African too Igo to sleep too
Sorry Lisa
Username: Ubba
Post Number: 127
Thanks guys, am trying to do last time factory bin download and see what happens, and then if nothing (which is what I think will happen) will try again tomorrow. I truly appreciate your help African and Plymouth, you guys have been terrific.
Username: Plymouth
Quebec city, Quebec
Post Number: 469
Lisa unplug for the night that take 1 hour for clear data like code last chnnel etc.
Username: Ong_tu
Post Number: 342
Three idiots my god I would laugh except for the tripe you fed this poor girl!
Username: Ubba
Post Number: 128
Well, I hooked up my receiver to original cable, all worked out, yet when I brought it back to my cable, have no quality. It's the problem with the loop I think. So, have to figure this one out, but thank you for all your help.
Kenya
Post Number: 1886
what kind of loop do you have?
Username: Plymouth
Quebec city, Quebec
Post Number: 473
I'm happy for you Lisa
Good TV
Home > Message Board > Home Video > Satellite TV > Archive through March 03, 2008 > Need help but people started cursing,... [ « Previous ] [ Next » ]
