Thread: NFUSION Freezing |
Bronze Member Username: Xpehbam
China,
NC
Post Number: 72 Registered: Jun-05
| Posted on Friday, February 29, 2008 - 01:51 pm: |
Hi! This is just me or everybody has freezing problem on NFUSION receivers? My receiver freezing almost every 20-30 min. Sometimes every 3 min. |
Silver Member Username: Bill038
Post Number: 509 Registered: Sep-06
| Posted on Friday, February 29, 2008 - 02:13 pm: |
What bin do you have? |
China,
NC
Post Number: 73 Registered: Jun-05
| Posted on Friday, February 29, 2008 - 02:21 pm: |
I think 1.44, the new one from couple days ago..But I have this problem for last couple weeks..And I am not sure why? |
Post Number: 510 Registered: Sep-06
| Posted on Friday, February 29, 2008 - 02:24 pm: |
Do you have the proxy server turned off. I installed it yesterday and have no problems, but I'm not using a proxy server either. I think you were supposed to do a reste before the install and one after. |
China,
NC
Post Number: 74 Registered: Jun-05
| Posted on Friday, February 29, 2008 - 02:31 pm: |
Thank you! I will try that later today...I will posted.. |
Post Number: 511 Registered: Sep-06
| Posted on Friday, February 29, 2008 - 02:36 pm: |
YW |
Gold Member Username: Saqeeb9000
Post Number: 2548 Registered: Oct-07
| Posted on Friday, February 29, 2008 - 06:46 pm: |
VB .. freezing problems.. i know bin 1.44 have some freezing problem. but if you turned off proxy it works fine.. but you said u have this problem for couple of weeks now.. try to change epg to mannual instead of automatic.. |
China,
NC
Post Number: 75 Registered: Jun-05
| Posted on Sunday, March 02, 2008 - 09:42 am: |
Thanks everybody! It's better now,I redownload everything, reboot, change epg to mannual, and now it's working much better (last night freeze only two times) Thank you.. |
