Thread: 119/110 problem |
Bronze Member Username: Cdeepak
Post Number: 15 Registered: Jan-07
| Posted on Friday, February 29, 2008 - 10:32 am: |
If I try to get both 119 and 110 on same dish, I am loosing quality on either 119 or 110. any solution? I am thinking to use seperate dish. |
Gold Member Username: Rtap
FL
Post Number: 1927 Registered: Jan-07
| Posted on Friday, February 29, 2008 - 10:34 am: |
if you are using a diseq switch replace it.switches are known for giving problems.also check all connections, also check your settings in antenna setup. |
Gold Member Username: Kirankumar
Kenya
Post Number: 1811 Registered: Oct-07
| Posted on Friday, February 29, 2008 - 11:26 am: |
before changing your switch,post your settings so we can take a look at it |
New member Username: Satchat
Post Number: 10 Registered: Feb-08
| Posted on Saturday, March 01, 2008 - 04:23 pm: |
I have a 18inch Dish and I am trying to get both 110 & 119 using two LNBs ... as soon as I attached another LNB ... my signal level went down on 110 !!! ... Any idea why ?! ... Do I need a big dish ?! Thanks |
Gold Member Username: Saqeeb9000
Mughe dard rehta hai, ...,
Mujhe bhook ...
Post Number: 2581 Registered: Oct-07
| Posted on Saturday, March 01, 2008 - 04:25 pm: |
ok for 119 you have to change freq to 12ooo somethign it will give you more signals.. |
Platinum Member Username: Lklives
Post Number: 14126 Registered: Jan-06
| Posted on Saturday, March 01, 2008 - 04:36 pm: |
U just need to align the dish with 2 LNB's correctly, have a working disque switch, good cables and connections... then input the corresponding antenna settings, scans the satellites, set the date and time, reboot the receiver, upload the latest fix, let the keys roll in..and watch TV.. |
Silver Member Username: Madflea168
Post Number: 296 Registered: Jan-08
| Posted on Sunday, March 02, 2008 - 02:49 am: |
possibly the skew. check dishpointer.com for more details. then do your settings. |
