Home > Message Board > Home Video > VCR > Record from my comcast DVR to VCR - n...
Author Thread: Record from my comcast DVR to VCR - not working?!
Username: Hezzylicious
I'm trying to record shows I have taped on my Comcast DVR to my Sylvania VCR. My boyfriend has the VCR hooked up to the dvr the correct way - it works when we use a friend of ours' vcr.. but when we try to use either of our vcrs it will not record. We set it to aux (antenna) or video 2 - depending on how we have it hooked up and it will not record or play back either way. Like I said, I dont think its how we have it hooked up, but maybe a problem with the vcr not recording off a channel as high as 800. I really have no idea. Any ideas?
Relevant Product Info
Username: Ieee488
Post Number: 60
Perhaps, you have connected the output from the DVR to the output on the VCR.
You need to make sure that OUTPUT is going into an INPUT.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > VCR > Record from my comcast DVR to VCR - n... [ « Previous ] [ Next » ]
