Thread: South Asian Channels moved to 118.7 |
Bronze Member Username: Reach_honey
Post Number: 91 Registered: Mar-05
| Posted on Thursday, February 28, 2008 - 04:07 pm: |
Just found that those channels have been moved to 118.7 So now what will be my antenna settings for that 118.7 Right now I have only 110(echo8,10),119(echo 7) & 148(echo 1,2). Any one has any idea about it. Looking from below document. http://www.dishchannelchart.digiblur.com/beam.pdf |
Platinum Member Username: Lklives
Post Number: 14053 Registered: Jan-06
| Posted on Thursday, February 28, 2008 - 04:56 pm: |
U'll need to add a CB 2008 LNB...gets both 118.7 and 119... 118 is 10750 freq... |
Gold Member Username: Nydas
Post Number: 8630 Registered: Jun-06
| Posted on Thursday, February 28, 2008 - 05:18 pm: |
It is not as easy as that. You will need a 30-33" Dish. There are people who have obtained signals on a 20" oval, but the signal quality is poor. There is also a scanning sequence you will need to adhere to. There are at least 3-4 extensive threads in the last 2 months in this forum, explaining exactly what is needed. "Mad Flae" has the most knowledge on it acquired directly from experience. |
Post Number: 14056 Registered: Jan-06
| Posted on Thursday, February 28, 2008 - 06:08 pm: |
118° (Circular 10750) dual LNB $19.95 This is the LNB for the new 118°W (Anik F3 / 118.7° / 118.8°) satellite. With this special LNB, you can get BOTH 118 and 119 at the same time! Works with both Free-to-Air and Original DN Receivers! Requires: 30-inch or larger dish Compatible with DirecTV, Free-to-Air (DiSEqC, 22KHz), and legacy switches (SW21, SW44, etc) Not compatible with DishPro switches and/or DishPro (stacked) LNB's SPECS Polarization: Circular Input Frequency: 11.70 - 12.75 GHz LO Frequency: 10.750 GHz Noise: 0.3 dB Dual-output (ready for 1 or 2 receivers) SETUP INSTRUCTIONS Using a 30-inch or larger dish, aim with the following settings: Satellite Name: 118°W (Anik F3) or 119°W (Echo7) LNB Type: Standard (or Single) LO Frequency: 10750 or 10600 MHz Finally, do an AUTO SCAN or a BLIND SCAN For some the following settings may work better or give you more channels: LNB Type: Universal LO Frequency: 9750 MHz HI Frequency: 11250 MHz ALTERNATIVE SETUP If there are any missing channels, MANUALLY scan them in. You can refer to the channel list at Lyngsat.c*om To add Anik F3 Antenna Setup A) Scroll to Edit TP/Satellite press (OK) B) Scroll to bottom you will see the word NEW press (OK) C) On this board highlite one character at a time and press (OK) when you finish entering these characters, if it looks like this Anik F3/Ku ..press (OK)should be at the bottom next to del. next you will see this. Down Frequency Symbol Rate Polarity Pull up.....http://www.lyngsat.co*m/anikf3.html here you will find all the TPs for Anik F3. If you don't have a HD Receiver don't bother entering the TPs outline in green. I will post the first TP for you. Down Frequency....11715 Symbol Rate...20,000 Polarity V yes its circular polarity with a 10750 freq.. |
Post Number: 8637 Registered: Jun-06
| Posted on Thursday, February 28, 2008 - 06:12 pm: |
LK is catching up with her homework. This information has already been posted 3 times in the 118 thread here. |
Post Number: 14058 Registered: Jan-06
| Posted on Thursday, February 28, 2008 - 06:31 pm: |
Actually I posted this stuff 6-8 months ago here...U're always too busy c/p and arguing to ever know whats going on.. BTW..for U that have DN subscription, DN is coming to the house and swapping the 121 LNB out to the 118 for ya, free...they've been doing it for months now.. |
Post Number: 8638 Registered: Jun-06
| Posted on Thursday, February 28, 2008 - 08:59 pm: |
LK: To you Ignorance is bliss. So live and swim in your bliss. You know nothing about how to set up 118.7 |
Post Number: 92 Registered: Mar-05
| Posted on Thursday, February 28, 2008 - 09:09 pm: |
Guys, Just so you know. I hav subscribe to DISH network as well and I already have 3 dish at my house and I'm getting ZEE tv(because that is what I have subscribed too). So if I'm getting DISH with current DISH then why do I need to add one more DISH or LNB? You are making me confused... |
Post Number: 8641 Registered: Jun-06
| Posted on Thursday, February 28, 2008 - 09:16 pm: |
Dish Network have a upgrade kit specifically to get the 118.7. With the number of dishes and receivers, it might be worthwhile finding out more about the kit. The DIY method is cheap, but you can get into trouble if you have more than one receiver. You might be better off using the Dish upgrade. Call them to find out. |
Silver Member Username: Madflea168
Post Number: 291 Registered: Jan-08
| Posted on Thursday, February 28, 2008 - 10:08 pm: |
dn has upgreade kit for converting super d to 500+ or 1000+. since you have subscription to dn, just let them do the work, after they are done with the antenna, you can play with your setting on your fta box. |
Post Number: 14063 Registered: Jan-06
| Posted on Thursday, February 28, 2008 - 11:27 pm: |
Thats for echoing my remarks Mad...maybe nalin will undrstand for once.. yes like I said, DN subscribers are getting this installed for free..no need to do it yourself (DIY)...thats stupid.. |
Post Number: 93 Registered: Mar-05
| Posted on Friday, February 29, 2008 - 12:43 am: |
I already have two legal receivers from DISH. And I have one DISH which has 3 LNB's out of which one is being used for HD(129) and other is used for 110,119. Second dish has one LNB and points to 148. They have their setup done way back and I'm using my viewsat has 3 rd receiver. There is nothing change here untill 2 days back. Suddenly you guys are talking about changing dish and connection and converting kit. I don't understand why you need that. Installation is already done like 4 months back what other installation you are talking about? |
Post Number: 14072 Registered: Jan-06
| Posted on Friday, February 29, 2008 - 09:36 am: |
most all internationals are going to the 118..if ya want the 118, ya need a new LNB...so thats the installation we are talking about..if ya don't have that particular DN package, U will have to install it yourselg..it all depends on what U subscribed too...call DN and ask them..tell em a friend had their LNB switched by DN and gets internationals, how come U don't...play dumb... |
Post Number: 94 Registered: Mar-05
| Posted on Friday, February 29, 2008 - 01:03 pm: |
LK, I'm already subscribed to 3 international channels out of 15 right now. And I'm already getting it on my legal receiver. Then why i'm not getting it on VIEWSAT. That is what I'm asking. So for that I wanted 118.7 Antenna setup description where I can try to find out while scanning it |
Post Number: 295 Registered: Jan-08
| Posted on Friday, February 29, 2008 - 01:53 pm: |
maybe the channels you are getting from dn is not at 118 yet, perhaps you need to play around the settings on your vs. |
Post Number: 14083 Registered: Jan-06
| Posted on Friday, February 29, 2008 - 02:03 pm: |
With Viewsat now...U are getting NOTHING cause Viewsat and Sonicview have an ECM today on BOTH Dishnet and Bev... |
Silver Member Username: Dizasta
Post Number: 129 Registered: Nov-06
| Posted on Friday, February 29, 2008 - 02:11 pm: |
Since thread is on here is my question, I have already 118.7 hooked up with the dish by DishNetwork two days ago. Now this weekend I am going to hook it up with the box i checked before there was no 118.7 or anik f3 or whtever u call it. Now do i have to add them manually or there is a channel or sat file that i can upload in. Regards, |
New member Username: Bazzoon
Post Number: 8 Registered: Aug-07
| Posted on Friday, February 29, 2008 - 03:32 pm: |
reach honey Maybe you are getting these internationals from the 148 bird which has internationals too. This one does not need to use new setting. You are good to go. What is happening is that channels that were on 121 are moving to 118.7 Hope this removes your confusion. |
Silver Member Username: Rekman
Mntl-Quebec-...
Post Number: 319 Registered: Jun-06
| Posted on Friday, February 29, 2008 - 05:59 pm: |
HI friends NALIN ...my problem have not been solved.. am still looking for help for my LNB 118.8 & 119 as i said I pointed to 61.5 ECHOSTAR WEst... SO I SCREW it on the 61.5 Echostar WEst... I set the Receriver as follows. Dish POINT out to 61.5 ECHOSTAR 7 Satellite.............. 119 Echostar 7 LNB POWER................ON LNB TYPE.......(change SINGLE into)UNIVERSAL LNB Freq ..........9.750/10.600 22KHz ..............Auto DisSeqc ............1.0 Commited.............4 Legacy SW...........OFF. LEVEL & QUality are GREEN above 90% I tried to Set the same for the 118.8 DISH Anik f3... BUT the QUALITY and LEVEl is giving me RED BARS.... I SCAN 119 Echostar 7... And I am getting ALL south east indian channels... But NO American channels are playing...I think the american are on the 118.8.. but its quality & level are RED ... -WHY is the 118.8 Dish Anik F3 not able to give Green quality and level??? -wat should i do so that 118.8 Dish Anik F3 get SAME level & quality as 119 echostar 7 ??? Because i also WANT to have AMERICAN channels.... HELP Me please. THANK YOU |
New member Username: Jattsober
Post Number: 9 Registered: May-06
| Posted on Friday, February 29, 2008 - 06:47 pm: |
Guys just wait for the new bin,,, its just ecm problem. No need to get the 30 inch dish or to change directions of the dish. Relax and watch some local channels till the coders find the fix. |
Bronze Member Username: Lookekhoshshans_1356
Tehran,
Tehran
Iran
Post Number: 90 Registered: Apr-07
| Posted on Saturday, March 01, 2008 - 10:57 pm: |
ok i just got the new DGL-1189S and cant seem to get the signals Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally do auto san and blind scan After that delet only the chanells Than put freq 12455 and SR 20000 Than press geen button I got than302 active chanells Nimiq2 Satellite Nimiq (2) LNB Power ON LNB Type Standard LNB Local Freq 11250 22KHZ off Diseqc 1 Skew -45 TP [1] 12223(12224) V SR 20000 Legacy SW None Positioner setting Disable all |
Tehran,
Tehran
Iran
Post Number: 91 Registered: Apr-07
| Posted on Saturday, March 01, 2008 - 11:00 pm: |
ok I did like this and I have 3040 chanells on 118.7 Anik F3 118.w I bought LNB DGL--1189s LNB Power======> ON LNB TYPE =========> Universal LNB Freq =====> 9750/10750 TP=====>11715 (V) SR 20,000 22KHZ ---------- Diseqc (Port) 3 Legacy SW None Position Setting Disable Finally do auto san and blind scan After that delet only the chanells Than put freq 12455 and SR 20000 Than press geen button I got than302 active chanells Nimiq2 Satellite Nimiq (2) LNB Power ON LNB Type Standard LNB Local Freq 11250 22KHZ off Diseqc 1 Skew -45 TP [1] 12223(12224) V SR 20000 Legacy SW None Positioner setting Disable all |
Tehran,
Tehran
Iran
Post Number: 92 Registered: Apr-07
| Posted on Saturday, March 01, 2008 - 11:08 pm: |
pakistan_and_indian_channels_on_118_ 11806 R tp 7 SR 20000 FEC 7/8 12033 L tp 22 SR 20000 FEC ? |
Post Number: 297 Registered: Jan-08
| Posted on Sunday, March 02, 2008 - 02:58 am: |
I tried create new sat or modify 119, did not work on my vs. the signals/quality are good, the channels are in, BUT in 4000+ range AND auto rolling, I dunno why. what worked for me is, I used 121 instead and add a tp @11715, lnb freq @ 10750, if your antenna is at the right place, you should get most of the international on 118. before scan, make sure you see the signal/quality on 11715. good luck. |
Post Number: 98 Registered: Mar-05
| Posted on Sunday, March 02, 2008 - 01:03 pm: |
Mad flea, I have 4 birds setup from Dish Netowrk. 1->echo 7 (119) 2-> echo 8,10(110) 3->129(for HD) 4-> 148(for South Asian channels) So I think I any one can post their TP and lnb frequency for South Asian Channels. I tired Auto/Blind Scan on 148,119. Did not et on any one.? If some one post their TP and lnb Freq then I can add that and do Scanning accordingly. I think any 118/119/148 bird will work |
Post Number: 14140 Registered: Jan-06
| Posted on Sunday, March 02, 2008 - 01:09 pm: |
Silver Member Username: Reach_honey
Post Number: 101 Registered: Mar-05
| Posted on Sunday, March 02, 2008 - 01:28 pm: |
So how do I use this I went to Lyngsat website I saw as 12224 R TP 1 and then I select {P} from there where I got a to see all channels. But now they have their Freq and TP and VPID and etc. So now what I'm supposed to do. I have Viewsat Ultra. I went to Antenna Setup and then select Channel setup and went to 119 and selected 12224 Freq but then I get nothing |
